Environment Canada Weather/Weather Warnings
  • #31
    1.17 is available.
    This adds those 'colorful Gifs' Robert requested. These are optional.
    Adds the option to direct speech to selected Speaker Clients.
    Also fixes the pronouniation of "Degrees" (hopefully) once and for all.
    Simply put, if the script had been edited using Homeseer's built in editor, it would effectively break the script. This is fixed. My bad.
    Zipped the whole thing. No need to rename anything.
    • #32
      Well, it looks like adding the graphic has damaged some of the speech. I'm on it.
      • #33
        hello Wadenut
        Assumes that I am very interested by the French version, made ​​me know when it is written, I will try the installation and I give you some news.
        • #34
          Moi c'est mon anglais qui n'est pas bon, alors si je peux t'aider..
          • #35
            Me that my English is not good, so if I can help ..
            • #36
              Adding the graphics caused more problems than I'd expected.
              The script has been updated to 1.18 and is now contained in a ZIP due to the additional files required.
              • #37
                Originally posted by Loup View Post
                hello Wadenut
                • #38
                  1.18 is a gem ! Works just fine !
                  Thanks Wadenut !
                  Neil
                  Newmarket Ontario
                  • #39
                    Thanks Wadenut !
                    Thanks for the praise.
                    Imagine my panic though this morning, just after having uploaded 1.17. when during the announcement, everything was askew. I hadn't expected the graphics to have such an effect. I took 1.17 down while I dealt with it, and found some opportunities for improvement at the same time.
                    "Wind" continued to be mis-pronounced, so I ended up prepending it in the spoken current and forecasts wilth "The" as in The wind". Seems to have worked.
                    The degree symbol shouldn't be a problem anymore either. That's been a be-ach all along.
                    Now, if it's done, I'll look at a french version. But I won't know if it's mis-pronouncing anything. Don't even know if my 'voice' will work.
                    • #40
                      hello Wadenut
                      • #41
                        hello Wadenut
                        I do not reuse has to operate your English version, I have not much knowledge but I want to learn, I was to find the flu cappable to quebec, but I do not know what to do, When I 'activates the events he made a mistake in the log, Ton scipt is complex and full of good work you do, but for novices c is more difficult to follow, before you have to start walking to get up, I work hard, thank you for your help it is very valuable ..
                        • #42
                          • #43
                            I've really done all I can at this time. To translate the script would be a massive job and I simply don't have the time right now. Perhaps later.
                            I've run the directions through a translator and posted them with the script for you.
                            All you need to do is select the device codes you want to use. The other options will work fine as is.
                            • #44
                              I understand that you have translated things for me ... Super ... but I take it a destination for the script?
                              Can you put ip on this page? I know that you make an effort to help me These and appreciate. thank you
                              • #45
                                Can you m'emvoyer the script by e-mail?
                                Please
