Contacting HomeSeer This Week
See more
See less
Environment Canada Weather/Weather Warnings
  • #61
    Put this file in your scripts directory.
    Rename it to MakeXMLRef.vb
    Create an event to run it ONCE.
    Run the event.
    • #62
      Run the event.
      It gives this as an error in the Log ...
      " (Running script, script run or compile error in file: MakeXMLRef.vb.txt1006:Expected ')' in line 1 More info: Expected ')' "
      You can see why you?
      • #63
        I did tell you to rename it
        • #64
          I rename it keeps its extension TXT why?
          I'll sure as I have renamed
          • #65
            I have a scipt that have a vb extension, which appears in txt .. I do not know why?
            • #66
              We obviously have a communication problem.
              Perhaps someone bilingual can help you out here. I have no idea how.
              • #67
                Sorry that you're angry, I did some manipulation and I change it to a suc vb
                Again sorry to disappoint you
                I think the market I do not mistake
                • #68
                  Loup:
                  If you are using Notepad, it wants to create a .txt file. However, there is a way to fix it:
                  • Click File, Save as...
                  • Type in the full name MakeXMLRef.vb
                  • Click the Save as type file type to select All Files
                  • Then click Save
                  When you first try to open the file MakeXMLRef.vb, windows will not "know" that .vb files are for Notepad. You will have to tell windows to use Notepad for .vb files. The first time you try you will see what to do
                  Paul
                  Paul
                  • #69
                    I am not angry. I was tired and frustrated.
                    Originally posted by pbibm View Post
                    Loup:
                    • Then click Save
                    Paul
                    Thank-you Paul.
                    • #70
                      http://www.microsofttranslator.com/
                      • #71
                        • #72
                          If anyone downloaded 1.20, I apologize.
                          It looks like when I Frenched the script, I broke Wind.
                          Wind was always n/a.
                          It's fixed now. V1.20.1 hopefully there's nothing else.
                          • #73
                            Salvation Wadenut
                            On my computer I use "ScanSoft Virginie_16Khz" which is the best in my opinion, easy to Setup, easy to find on the net....
                            • #74
                              Salvation Wadenut
                              Does that mean it's good? I was worried about the comma as a decimal point.
                              • #75
                                Hey...
                                Thanks Greg for this. Works great for me!!!
                                Much appreciate all your hard work.
                                Rob
