Here is a script originally posted by brianjhomeseer That I modified to control the 3m50 wifi thermostat. Hope that is OK
1 The script needs to be installed in the HS script directory change from txt to thm extension and then set up in Device Types.
2 You will also need to download and put curl.exe and the dll files in the homeseer folder in order for this to work. I got Curl from http://curl.haxx.se/download.html
3 Create one device s1 for the thermostat.
You will need to assign static IP to your thermostat then edit the IP lines in the script.
Discussion thread here: http://forums.homeseer.com/showthread.php?t=151605
