script help: Monitoring file system for changed file
  • script help: Monitoring file system for changed file
    All:
    I've got a webcam that is ftping a file to my homeseer server. I'd like to be able to write a job to look at that directory every minute and if a file has been added, email it to myself. The difficulty I'm having is that the file names are different (including a date/time stamp) so I can't just search for 'file.jpg'.
    Does anyone have some vbscript that can get this done? I'd appreciate it.
    Ken
    if you post some examples of the filenames then it should not be too difficult to do...
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      You may be able to use Blades BLLatestimage to assist with some of this: http://board.homeseer.com/showthread.php?t=143914
      Jon
        This is an example:
          Couple of different ways of doing this, if that is a random number generated at the end of the name (I guess the start is YYYYMMDD but don't know the last bit) then there is going to be no way of guessing it. If you take a look at the System.IO.File namespace there are a whole host of different of attributes and things in the directory you could experiment with. This should (providing you change the directory and file search) find if any of the files in the directory have been created this minute.
          Dim strFileSize As String = ""
          Dim di As New IO.DirectoryInfo(hs.getapppath & "\scripts\")
          Dim aryFi As IO.FileInfo() = di.GetFiles("*.txt")
          Dim fi As IO.FileInfo
          For Each fi In aryFi
          	If fi.CreationTime.ToString("dd/MM/yyyy HH:mm") = DateTime.Now.ToString("dd/MM/yyyy HH:mm") Then
          	        hs.writelog("FileInfo", fi.Name & " - was created this minute")
          	Else
          		hs.writelog("FileInfo", "File Not Created Now")
          	End If
          Next
          End Sub
          My Plugins:
            Thank you very much!
            That is doing exactly what I need - appreciate the bit of help.
            Ken
