[VB.NET] Flyport plugin....
  • [VB.NET] Flyport plugin....
    This script will control your Flyport.
    Consists of the vb script and the C code if you need to control outputs. Controlling outputs also requires a line to be added to your startup script. See starting comments. More in the discussion.
    Forgot to include the vb script. Added.. remove the .txt extension when installing. Change your IP address, choose a house code-- and set a recurring event to run the script. I run it every 45 seconds or so.
    To control the output-- you must replace the function in the default project with the one here.
    Plug-Ins Enabled:
