Unknown caller reported after 3 rings
    Steve
    I've got a slight problem with the CID package. The third ring is being interpited as the first ring of a new call. See log excerpt below. Is there any way to delay the modem reset or the time to recognize a new call to more than 7 seconds?
    2012-07-25 20:11:19Z ... Raw data from COM port = [RING]
    2012-07-25 20:11:19Z ... RING detected; last ring was at 6:47:01 PM
    2012-07-25 20:11:19Z ... Ring more than 7 seconds after last one. New call.
    2012-07-25 20:11:19Z ... Got RING; ring count = 1
    2012-07-25 20:11:19Z ... Raw data from COM port = [DATE=0725]
    2012-07-25 20:11:19Z ... Ignoring 'DATE'
    2012-07-25 20:11:19Z ... Raw data from COM port = [TIME=2011]
    2012-07-25 20:11:19Z ... Ignoring 'TIME'
    2012-07-25 20:11:19Z ... Raw data from COM port = [NMBR=1315363xxxx]
    2012-07-25 20:11:19Z ... Got Number: '13153633492'
    2012-07-25 20:11:19Z ... Raw data from COM port = [NAME=Grimaldi E]
    2012-07-25 20:11:19Z ... Got Name: 'Grimaldi E'
    2012-07-25 20:11:19Z ... process_ncid_data: starting, Name='Grimaldi E', Number='315363xxxx'
    2012-07-25 20:11:19Z ... Line=1, After reverse, Name = |E Grimaldi|
    2012-07-25 20:11:19Z ... In search_phonebook(), about to search for Number=315363xxxx
    2012-07-25 20:11:19Z ... returned from search_phonebook(), i_ret=0, phone_list_name='Ernie Grimaldi', blocked=False
    2012-07-25 20:11:19Z ... Announcing: There is a call from Ernie Grimmauldi
    2012-07-25 20:11:19Z ... Reseting modem
    2012-07-25 20:11:21Z ... Raw data from COM port = [OK]
    2012-07-25 20:11:28Z ... Raw data from COM port = [RING]
    2012-07-25 20:11:28Z ... RING detected; last ring was at 8:11:19 PM
    2012-07-25 20:11:28Z ... Ring more than 7 seconds after last one. New call.
    2012-07-25 20:11:28Z ... Got RING; ring count = 1
    2012-07-25 20:11:30Z ... Raw data from COM port = [RING]
    2012-07-25 20:11:30Z ... RING detected; last ring was at 8:11:28 PM
    2012-07-25 20:11:30Z ... Got 2nd RING with no CID info. Logging it as a call.
    2012-07-25 20:11:30Z ... Got RING; ring count = 2
    2012-07-25 20:11:30Z ... process_ncid_data: starting, Name='an unknown caller', Number='None'
    2012-07-25 20:11:30Z ... Line=1, After reverse, Name = |an unknown caller|
    2012-07-25 20:11:30Z ... Announcing: There is a call from an unknown caller
    2012-07-25 20:11:30Z ... Reseting modem
    2012-07-25 20:11:32Z ... Raw data from COM port = [OK]
    2012-07-25 20:11:39Z ... Raw data from COM port = [RING]
    2012-07-25 20:11:39Z ... RING detected; last ring was at 8:11:30 PM
    2012-07-25 20:11:39Z ... Ring more than 7 seconds after last one. New call.
    2012-07-25 20:11:39Z ... Got RING; ring count = 1
    What modem are you using? Are you using HSPhone or another package?
    -Rupp
      I'm using a MultiTech MultiModem MT9234zpx and no HSPhone. Other than the additional anouncement and logging of the "Unkown Caller" after the third ring, it works fine.
        Lou,
        I'm guessing (from the 'Steve' reference and the fact that the debug looks familiar) that this is regarding SnevlCID. You probably want to post this stuff in the SnevlCID discussion thread, rather than here.
        Let me look at this after work tomorrow.
        Steve
          Lou,
          There's a pretty easy way to up the time from 7 seconds, but I keep it kind of hidden. Please send me an email at snevl at msn dot com and I'll reply with a really simple instruction.
          Steve
