What does mean the /number at the end of the ip address?
IP and Serial Plugin
Originally posted by emabonacchi View PostWhat does mean the /number at the end of the ip address?
Cheers
AlHS 3.0.0.548: 1990 Devices 1172 Events
Originally posted by emabonacchi View PostHello.
I have made some changes in setting and now, on the startuo, homeseer crashes.
Can you tell me where the setting are stored in order to manually modifying the file?
Thank you.cheeryfool
Well, this is what i need:
I need an Arduino with Ethernet module, sending a string, and Hs2 receiving this and replying.
I know it is possible with this plugin and i know i am missing something in setting.....
I am a little new in configuring lan, web server and ports, so, i would like some help about......
For example, when i enable plugin and i set an ip address, homeseer automatically change web-server port from 80 to 81.......
It is frustrating for me...... i can't understand why this behaviour because i am a little new about this......
....scuse me for my bad english...... i hope i have explain and you can understand me.
Ema from Italy
For Arduino go here :http://board.homeseer.com/forumdisplay.php?f=1222
You may also take a look at this :http://board.homeseer.com/showthread.php?t=180804 But then again you will need HomeSeer 3
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
