Event Execution Delay Measurement Script
  • Event Execution Delay Measurement Script
    Poor mans HS2Sentry.
    From time to time, Event execution by Homeseer may become delayed due to uncontrolled resource management by HS, plugins, scripts or external influences.
    This script is capable of detecting this situation and taking action before the system becomes unuseable. This is useful under HS Standard where no software watchdog (HS2Sentry) exists as well as under HSPRO as an aid in analysing potential problems.
    Full documentation is in the ZIP.
    Features:
    Tracks event execution delay times in a Device String and Value.
    Optionally logs all activity controlled by the device status.
    Optionally logs warnings if execution time is greater than an independently set threshold.
    Optionally speaks a warning if execution time is greater than an independently set threshold.
    Optionally attempts to force a system restart if execution time is greater than an independently set threshold.
    Discussion can be found here: http://board.homeseer.com/showthread.php?t=155468
    Up and running here, Wadenut. What deltas are you and others getting?
    68 Z-Wave Nodes, 174 Events, 326 Devices
      Normally, I see about +/-1 ms. But when HS starts having problems, I've seen as much as +/-600 ms, and a gradual increase in ex times.
      I'm glad such a simple script can be of use to others.
        Update: v1.02 html tags are no longer written as text to the GUI log.
          1.05 has no functional improvments.
          Simply replaced Writelogex with Writelog for the benefit of those running older versions of Homeseer.
            v1.08 is posted above.
            Additional functions are described within the included documentation.
            Thanks go to Jon00 for his useful suggestions.
              v1.08.01
              Fixed a small bug.
              If graphing only was selected in v1.08, the calculated Min/Max values would be incorrect (=0).
              These values are also optionally provided as part of the graphing process (Jon00VDGraphing) and so were removed from the resulting device string.
              If TrackDV is selected, the Min/Max values are calculated and included withing the device strings.
                v1.12
                Fixed a couple of bugs no-one happened to notice.
                Moved configuration to an INI file
                Added several options.
                Will now detect delays in excess of the trigger period.
                I stongly suggest reading the included documentation prior to using, especially if upgrading from a previous version.
                  v1.12.1
                  - Fixes a small bug where the minimum delay time might become negative. This has occurred when the event frequency or the TriggerFrequency parameter in the configuration file are altered in vivo.
                  - Trigger Frequency is moved from the configuration to become a parameter to the running script. This makes altering the run frequency a one step process. Existing events will need to be modified as a result.
                  There should be no need for existing users to replace the configuration file. The old TriggerFrequency parameter in the Config section is now obsolete and can be removed if desired.
                  Full documentation has been updated accordingly.
                  This is a mod I've been using for some time now, but had forgotten to post.
