Event Execution Delay Measurement Script discussion
    #61
    5:10 PM script doing well.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
      #62
      Several improvements with 1.09.
        #63
        So script went from 1.08.2 to 1.09. Is it a drop in that I can do chaning only the dim variable statements stuff?
        - Pete
        Auto mator
        HS4 Lite -
          #64
          Yup.
            #65
            Thanks Greg. Updated to V1.09.
            Renamed it to Event Delay Check.vb and enabled the TTS sound for spikes. Running fine.
            Just now found a disabled plugin (CumulusR) still running. It started to error out last night so I disabled it; but it still ran all night (with VB SQL errors).
            Just noticed that there is no space or line return on the text for seconds for the updated script V1.09?
            - Pete
            Auto mator
            HS4 Lite -
              #66
              Did you read the updated doc?
              Your caption is showing the "seconds" twice. You can turn that off in Jon's config for the graph. ShowCurrentValue=0, ShowLowHighValues=0. Looks much better.
                #67
                Thank you Greg.
                What "me" read the docs?
                Adjusted. Working well.
                - Pete
                Auto mator
                HS4 Lite -
                  #68
                  Thank you Greg.
                  I know... it's a man thing.
                    #69
                    Just a question.
                    Does this look normal to you guys?
                    Why would my "Min" be a negative number?
                    12/4/2012 6:18:00 PM ~!~Info~!~Running script in background: Event Delay Measurement112.vb
                    12/4/2012 6:18:08 PM ~!~EventDelay~!~Current delay: 1.593 seconds [Delta: 0.437 Min: -58.938 Max: 6.828 @ 12/2/2012 11:00 AM] Last Event: EventDelayMeasurment.  Scripts running: Jon00RCCNM_A.vben,Event Delay Measurement112.vb
                    Tim
                    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
                    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
                    No, Im from Iowa. I only work in outer space. Captain Kirk
                      #70
                      You may have an older version. I thought I'd fixed that.
                      Do make sure you're running the script at the same frequency as you've provided in the parameter.
                      For instance, my event frequency is 1 minute ::: Run script: Event Delay Measurement.vb("Main","1")
                        #71
                        I do have the latest, 1.12, in your post in the Script Library.
                        Tim
                          #72
                          My bad.
                          I had corrected the negative MinTime back in late September, but had forgotten to post the new version 1.12.1. Posted today.
                          This also will require a small change to your existing event. Documentation is updated accordingly.
                            #73
                              #74
                              I don't know why or what I am doing wrong. I went through everything, twice, and it just doesn't look right.
                              Here is from the log file -
                              5/27/2013 8:42:53 AM ~!~Event~!~Running script in background: Event Delay Measurement.vb("Main","2")
                              5/27/2013 8:42:53 AM ~!~EventDelay~!~Current delay: 53.062 seconds [Delta: 0 Min: 21.265 Max: 53.109 @ 5/27/2013 12:16 AM] Last Event: EventDelayMsrmnt.  Scripts running: SnevlWeatherWarnings.vb,Event Delay Measurement.vb
                              This is the latest file from your post and on a new machine with a new setup running HS .80.
                              Tim
                                #75
                                You've defined the run frequency as 2 minutes. Your event needs to run every two minutes as well. I can't tell if this is the case or not from your info.
                                I do suggest that one minute would be a better choice.
                                If everything IS set up properly, then you probably do have the delay as it's been reported. IE. The script is doing its job.
