It's in the ZIP archive. The file needs DailyReminders.ASH (not ASP) should be in your HTML directory. If it is there, when are you seeing this error?
Daily Reminders
v2.12a has been uploaded. It replaces the web page file, DailyReminders.ash. It will only be necessary to replace this file in \Homeseer\html\ to correct the problem over v2.12.
This occurred when I modified the file to be compatible with both HS2 and HS3 so I could avoid having to edit it for each version of Homeseer separately.
Thank-you Loup for pointing out the problem.Real courage is not securing your Wi-Fi network.
Well, partially it seems.
If you unpack the whole Zip file into your Homeseer directory, it will create a directory called \DailyReminders under Homeseer\Data and put the sample file, DailyReminders.csv inside.
If that file isn't found, the program will attempt to create an empty data file. Unfortunately, it doesn't create the folder (\DailyReminders\) as well (my bad again) and so, can't find the path.
If you unpack the "Entire" Zip file into your Homeseer root directory, all should be well, as all the necessary files will fall into their proper locations.
I'll see about having the directory created as well in future.Real courage is not securing your Wi-Fi network.
You should have the following:
\Homeseer\Config\DailyReminders.INI <---- You need to do your set up here.
\Homeseer\Data\DailyReminders\DailyReminders.csv
\Homeseer\html\DailyReminders.ash
\Homeseer\Docs\Daily Reminders.pdf
\Homeseer\Scripts\DailyReminders.vben
Yes, in the ZIP, the data file is in the wrong place. Just create the directory \data\DailyReminders\ and move the file \data\DailyReminders.csv into it. I'll fix the archive... again.
I need a vacation.Real courage is not securing your Wi-Fi network.
Originally posted by Loup View PostOk, for not wrong, I have to install a folder data "DailyReminders" and instaler "DailyReminders CSV" has inside.
Like that with you too ??
I wanted to correct the directory creation issue first to avoid all this in future, but I just don't have time today.Real courage is not securing your Wi-Fi network.
What do you expect to happen?
Provided everything has been installed, you should have three devices in Location1 = Daily Reminders; Latest Reminder, Next Reminder, and Today's Reminders. You should also have three events in the category Daily Reminders; Next Daily Reminder (this is rescheduled each time a reminder is to be scheduled. If you enter a reminder with the proper date and time format, the scheduled date time will either be that date/time or midnight; whichever comes first.), Daily Reminders VR (B) (This is for retrieving reminders over the phone or by voice recognition), and Daily Reminders Redirection (this probably won't be used... it's for redirecting the reminders to email, twitter, etc.)Real courage is not securing your Wi-Fi network.
