Two problems: one weird and one "old"
I have installed both the SNEVL Latitude scripts on my HS computer (a HomeTroller 2) and Btraced on my Iphone 5 (ios6).
The weird problem:
If I have UltraWeatherbug enabled then SnevlLatitude.vb will not run. When I envoke SnevelLatitude.vb the following error is returned:
"An unexpected error occured in the ActionUIFormat() function/subroutine: [System.IndexOutOfRangeException: Index was outside the bounds of the array, at HSPI_ULTRAWEATHERBUG.HSPI.ActionUIFormat(String Action)]
It looks to me that SNEVL is somehow invoking UltraWeatherbug - which then encounters an error.
My "old" problem:
Eventhough I have installed Btraced 1.1.1 the Iphone seems to go to sleep and will not upload trip data in real time. HS will have the following error in its log:
Web Server login failed from xx.xxx.xxx.xx User: Btraced
and then block Btraced from further access for a period. When I turn Tracking Off on the Iphone (and not changing anything on the HS side) it will uipload the trip data points.
I would really like to get this application working - any suggestions?
JimO.
Snevl Latitude Version 2 Discussion
Guest replied
Originally posted by stevea View PostOh I get what you mean. I thought you meant the track map with the animation.
You may be able to do what you are talking about. You need to take the device string for the position, and extract the link address. Right now it is a hyperlink to take you to the map. You don't want the hyperlink, you just want the place the link would take you. Right now, the device string is something like this:
PHP Code:<a href='http://maps.google.com/?q=12.345678,-123.456789' target='_blank'>Address of the place</a>
Code:Sub Main(ByVal param as Object) Dim orig as String = hs.DeviceString("G40") 'The 'position' device Dim origs as String() = orig.Split("'"c) hs.SetDeviceString("X10",origs(1)) 'The device you want to use End Sub
Steve
Originally posted by jayman13 View PostWill try and figure something out. Thanks! I do like your device images but I have noticed since I have been using btraced the images often don't load at all. Perhaps its the frequency of changing data points?
Steve
Originally posted by jayman13 View PostThanks. But how about the ability to put html in hstouch. I know your active map from Snevl would be hard to get in there but on the iphone it looks like you can go to "http://maps.google.com/?q=" and then add the string of the device for position or location and it will open up html interface for google maps so you can scroll around, etc... Anyway to do this?
Steve
Originally posted by jayman13 View PostHey Steve. I am trying to get me and my wife's location on Hstouch using the maps.google website. I see that on the computer I can go under status and click on the device called position or location and it will take me to the maps.google page. Do you know how I can implement this into hstouch? I was hoping to use that instead of the track map.
I'm afraid the "active" map (the one you get when you click on the "Latitude on Map" link) is not something you can easily put into HSTouch. The static map images (created and placed in devices you define on the "People" tab for each user) were put into Snevl Latitude specifically for HSTouch. Each time one of the people you are tracking has moved, Snevl Latitude will create a new static map (or multiple static maps) and put the image in the device string. Then you can include the device on one of your HSTouch screens.
For each person in our family I create two maps: One that is a roadmap track of the last 20 locations, and one that is a satellite view of the latest position. I then have a series of location screens where I can see both the track history and the current location for myself, my wife, and both daughters. (The daughters are in college, and are not really happy I do this, but they humor me)
Steve
Using google maps
Originally posted by simonog View PostSteve: I am getting a file called snevlBTraced debug file created which contains a line about a file being passed to snevllatitude for processing.
Is an xml file created every time a reading comes in from BTraced, passed to Snevl Latitude, and then deleted?
simon
simonLast edited by simonog; January 15, 2013, 01:35 PM.
Simon,
One way to see when the phone is sending data is to turn on debug in Snevl Latitude. It will write something to the debug log file (in the logs directory) each time the phone contacts your server. That may not be what you are looking for, but it is an option to help track down the issue.
Steve
Gogs
One question before I contact the BTraced developers - do you know when your phone is sending data, or just when the readings change? I can't see an easy way to check that in HS which is why I was looking at the Track Map device Time Last Change on the HS status page - an easy field to monitor (which Steve updates on receipt of every set of readings).
with my phone unmoved for 12 hours, data has been received recently at:
5:36:49
6:37:16
7:09:06
7:10:39
7:11:06
7:11:33
7:13:06
7:14:10
7:48:56
8:17:48
8:18:22
which is enough to show how it varies from around 30 seconds to one gap of an hour! completely correctly, none of them shows a movement.
Do you know a way independently to monitor what's coming in? if so, I can try that just to double check.
Simon
Simon,
I looked at the code. It seems that I re-set the device string on the devices even if the position doesn't change. If you are using Latitude, the logic would not actually try and update the devices. However, for Btraced I ended up updating at the end of every download, even if I don't generate a new map. The reasoning is kinda complicated and a little fuzzy to me now, but it was to deal with the fact that data from Btraced might not be in time order.
So, I think the times you see are tied to when a set of data got downloaded from Btraced to Snevl Latitude.
Steve
Originally posted by stevea View PostYou're pretty close to right. Actually, each obs has a "First heard" and "Last heard" for a given point in the track history. If a point is determined to be at the same location as the previous report (based on the "Minimum Chage Distance" in the config), the then "Last Heard" is updated and the number of observations is bumped.
Steve
if there is a track map device, when does its Time Changed field get updated?
I find my Position device Last Change does not get updated yet the Track Map Last Change is being updated at apparently random intervals (it is set to 30 minutes and 300 metres in btraced so should be getting at most one reading per half hour as the phone is stationary).
here is a sample of change times:
21:19:38
21:20:03
21:24:08
21:24:30
21:25:13
21:25:34
21:25:49
21:26:02
21:26:38
21:26:56
21:27:39
21:27:56
21:29:39
these times seem quite irregular to me. (Times are obtained by a simple script which reports when the Last Change field changes on the Track Map for that particular phone.)
Simon
