Contacting HomeSeer This Week
See more
See less
[VB.NET] my.Alert
  • #16
    Tonlof thanks for your help. I missed the fact that the website also showed a single day. Nice job. Simple and everything is working. Really appreciate your response I had spent several hours learning about regex over the past few days. Nice to have this part working.
    • #17
      tonlof-
      Several TV Channel program info.
      How and which site are you using for this? TVGuide?
      My cable co. has this page-
      http://mediacomtoday.com/tv/login.ph...1&submit=Enter
      But you have to interact with it ie your zip code. Then the grid loads with this url- http://mediacomtoday.com/tv/listing_grid.php?page=grid
      So I am not sure this will work, will it?
      Tim
      FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
      HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
      No, Im from Iowa. I only work in outer space. Captain Kirk
      • #18
        Hi Tim, the site I use is from local paytv operator and I don't think you can use it for your needs. Have you look at HSTV?
        Originally posted by fungun View Post
        tonlof-
        Tim
        Tasker Plugin / Speech Droid
        Tonlof | Sweden
        • #19
          Dan,
          Script does look very powerful and useful. Need a bit of help. Keep getting this same error in the log file when looking up cnn breaking news. Please see attachment.
          thanks
          Tom
          Tom
          • #20
            I've re-installed the script file, .ini file( copied and pasted your example) and recreated the event. Seem to get the same log error(post #19). Can't seem to figure it out. Would appreciate any help you can provide. Thanks
            Tom
            • #21
              MyAlert Error - Anyone know what Error Means
              Do of the any other users here know what this error means. Thanks
              7/14/2013 7:45:26 AM SCR Option Strict OffImports System.TextImports System.Text.RegularExpressionsPublic sSettingLogLevel As Integer = 0Public sConfigINIPath As String = "my.Alert.ini"Public sConfigProfile As StringPublic sConfigURL As StringPublic sConfigRegExSearch As StringPublic sConfigRegExReplace As StringPublic sConfigDeviceString As StringPublic sConfigDeviceOn As StringPublic sConfigDeviceOff As StringPublic sConfigDeviceToggle As StringPublic sConfigSpeak As StringPublic sConfigRun As StringPublic sConfigEvent As StringPublic sConfigMedia As StringPublic sConfigEmail As StringPublic bConfigHTML As Boolean' ------------------------------------------------------------Public Sub monitor(ByVal oParameters As Object) Dim sParameters() As String Dim sData As String Dim sURL As String Dim sRegExPattern As String Dim sRegExReplace As String Dim sLogLevel As String dlog("Executing my.Alert",2) sParameters = Split(oParameters.ToString,"@") If oParameters Is Nothing Then hs.WriteLog("my.Alert","Fatal Error") Return End If dlog(sParameters.GetUpperBound(0) + 1 & " parameter(s) specified: " & oParameters.ToString,3) Try dlog("Setting sSettingLogLevel to " & sParameters(0),3) sSettingLogLevel = sParameters(0) Select Case sSettingLogLevel Case 3 sLogLevel = "Debug" Case 2 sLogLevel = "Info" Case 1 sLogLevel = "Error" Case 0 sLogLevel ="None" End Select dlog("Setting logging level to " & sLogLevel,2) sConfigProfile = sParameters(1) dlog("Loading '" & sConfigProfile & "' profile (" & sConfigINIPath & ")",3) If hs.GetINISection(sConfigProfile, sConfigINIPath).Length 0 Then dlog("monitor(): New data detected",3) If sConfigDeviceString "0" Then dlog("monitor(): Updating device string for " & sConfigDeviceString & ": " & sData,3) hs.SetDeviceString(sConfigDeviceString, sData) End If If sConfigDeviceToggle "0" Then dlog("monitor(): Toggling device status for " & sConfigDeviceToggle,2) If hs.DeviceStatus(sConfigDeviceToggle) = 3 Then hs.SetDeviceStatus(sConfigDeviceOff,2) Else hs.SetDeviceStatus(sConfigDeviceOff,3) End If End If If sConfigDeviceOn "0" Then dlog("monitor(): Turning on " & sConfigDeviceOn,2) hs.SetDeviceStatus(sConfigDeviceOff,2) End If If sConfigDeviceOff "0" Then dlog("monitor(): Turning off " & sConfigDeviceOff,2) hs.SetDeviceStatus(sConfigDeviceOff,3) End If If sConfigRun "0" Then dlog("monitor(): Executing command " & sConfigRun,2) hs.Launch(sConfigRun) End If If sConfigSpeak "0" Then dlog("monitor(): Announcing " & sConfigSpeak,2) hs.Speak(sConfigSpeak) End If If sConfigMedia "0" Then dlog("monitor(): Playing " & sConfigMedia,2) hs.PlayWavFile(sConfigMedia) End If If sConfigEmail "0" Then dlog("monitor(): Sending e-mail to " & sConfigEmail,2) hs.SendEmail(sConfigEmail,sConfigEmail,sConfigProfile,sData) End If If sConfigEvent "0" Then dlog("monitor(): Executing event --- " & sConfigEvent,2) hs.TriggerEvent(sConfigEvent) End If Else dlog("monitor(): No change was detected",3) End If Catch Ex As Exception hs.WriteLog("my.Alert","Script Exception Error: " & Ex.Message) End TryEnd Sub' ------------------------------------------------------------Sub Main(ByVal sParams As String) dlog("Please read the instructions on how to configure my.Alert.",1)End Sub' ------------------------------------------------------------' ------------------------------------------------------------Sub dlog(ByVal sError As String, Optional ByVal iLevel As Integer = 3) Dim sLogLevel As String ' ' 0 = None ' 1 = Errors ' 2 = Info ' 3 = Verbose ' If sSettingLogLevel = iLevel And sSettingLogLevel 0 Then Select Case iLevel Case 3 sLogLevel = "Debug" Case 2 sLogLevel = "Info" Case 1 sLogLevel = "Error" End Select hs.WriteLog("my.Alert", sLogLevel & " --- " & sError) End If End Sub' ------------------------------------------------------------' ------------------------------------------------------------Function ProcessData(ByVal sURL As String, ByVal sRegExPattern As String,ByVal sRegExReplace As String) As String Dim sData As String Dim sResult As String Dim sSavedData As String dlog("ProcessData(" & sURL & "," & sRegExPattern & "," & sRegExReplace & ")",3) If sURL.Contains("{{") Then sURL = ParseVariables(sURL) sData = GetData(sURL) dlog("ProcessData(): size of received data is " & sData.Length,3) sData = PrepData(sData) 'dlog("ProcessData(): original data : " & sData,3) Try Dim RegEx = New RegEx(sRegExPattern) sResult = RegEx.Match(sData).Groups(sRegExReplace).Value Catch ex As ArgumentNullException dlog("ProcessData(): One of the parameters in the " & sConfigINIPath & " file has not been configured properly",1) Return "no data" Catch ex As ArgumentException dlog("ProcessData(): Invalid Regular Expression",1) Return "no data" Catch ex As Exception hs.WriteLog("my.Alert","ProcessData() Exception Error: " & Ex.Message) End Try dlog("ProcessData(): size of processed data is " & sResult.Length,3) dlog("ProcessData(): data : " & sResult,3) If bConfigHTML True Then sResult = CleanData(sResult) End If sResult = FormatData(sResult) dlog("ProcessData(): " & sResult,3) sSavedData = hs.GetINISetting(sConfigProfile, "Content", "0", sConfigINIPath) dlog("ProcessData(): Saved data is " & sSavedData.Length & " long, new data is " & sResult.Length & " long",3) If sSavedData sResult dlog("ProcessData(): Change detected, saving data to " & sConfigINIPath,2) hs.SaveINISetting(sConfigProfile, "Content", sResult, sConfigINIPath) Return sResult Else dlog("ProcessData(): No change detected",2) Return "" End IfEnd Function' ------------------------------------------------------------Function GetData(ByVal sURL As String) As String Dim sData As String Dim hRequest As System.Net.HttpWebRequest Dim hResult As System.Net.HttpWebResponse Dim iStatusCode As Integer Dim sStatusDescription As String dlog("GetData(" & sURL & ")",3) Try hRequest = CType(System.Net.WebRequest.Create(sURL), System.Net.HttpWebRequest) hRequest.ContentType = "text/html" hRequest.UserAgent = "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_8_2) AppleWebKit/537.17 (KHTML, like Gecko) Chrome/24.0.1309.0 Safari/537.17" hRequest.Method = "GET" hRequest.AllowAutoRedirect = True hRequest.TimeOut = 10000 hResult = CType(hRequest.GetResponse(), System.Net.HttpWebResponse) iStatusCode = hResult.StatusCode sStatusDescription = hResult.StatusDescription dlog("GetData() HTTP response: " & iStatusCode & " : " & sStatusDescription,2) If iStatusCode = System.Net.HttpStatusCode.OK Then sData = New System.IO.StreamReader(hResult.GetResponseStream()).ReadToEn d() Else dlog("GetData(): An error has occurred while downloading data.",1) Return "ERROR" End If hResult.Close() Catch ex As Exception dlog("An error has occurred while downloading data from " & sURL & " : " & ex.ToString(),1) End Try dlog("GetData(): " & sData) Return sDataEnd Function' ------------------------------------------------------------Function PrepData(ByVal sData As String) 'dlog("PrepData(): Prepping HTML data") 'sData = Regex.Replace(sData, "]*[\s\S]*?", string.Empty) 'dlog("PrepData(): " & sData,3) Return sDataEnd Function' ------------------------------------------------------------Function CleanData(ByVal sData As String) dlog("CleanData(): Scrubbing HTML data") sData = Regex.Replace(sData, "", string.Empty) dlog("CleanData(): " & sData,3) Return sDataEnd Function' ------------------------------------------------------------Function FormatData(ByVal sData As String) Dim cTrimChar() As Char = { "*"c, " "c, "'"c, " "c} dlog("FormatData(): Before: " & sData,3) sData = sData.Replace(ControlChars.Tab,"") sData = sData.Replace(ControlChars.CrLf,"") sData = sData.Replace(ControlChars.Lf,"") sData = sData.Replace(ControlChars.Cr,"") Do While sData.IndexOf(" ") -1 sData = sData.Replace(" ", " ") Loop sData = sData.Trim(cTrimChar) dlog("FormatData(): After: " & sData,3) return sDataEnd Function' ------------------------------------------------------------' ------------------------------------------------------------' ------------------------------------------------------------' ------------------------------------------------------------Function ParseVariables(ByVal sInput As String) As String ' ' Examples: {{String:Y12}} {{Value:Y11}} ' Dim sOutput As String Dim sPattern As String = "(?\{\{(?String|Value)?\S\d{1,2})\}\})" sOutput = sInput dlog("ParseVariables(" & sOutput & ")",3) Dim r As New Regex(sPattern) Dim m As Match = r.Match(sInput) While m.Success 'dlog("ParseVariables(): " & m.Groups("cmd").Value & " parameter for " & m.Groups("device").Value,3) Select Case m.Groups("cmd").Value Case "String" dlog("ParseVariables(): replacing " & m.Groups("var").Value & " with " & hs.DeviceString(m.Groups("device").Value),3) sOutput = sOutput.Replace(m.Groups("var").Value, hs.DeviceString(m.Groups("device").Value)) Case "Value" dlog("ParseVariables(): replacing " & m.Groups("var").Value & " with " & hs.DeviceValue(m.Groups("device").Value),3) sOutput = sOutput.Replace(m.Groups("var").Value, hs.DeviceValue(m.Groups("device").Value)) End Select m = m.NextMatch() End While dlog("ParseVariables():" & sOutput,3) Return sOutputEnd Functionimports Schedulerimports SystemPublic Module scriptcode30#Region "Automatically generated code, do not modify"'Automatically generated code, do not modify'Event Sources Begin Public WithEvents hs As Scheduler.hsapplication Public WithEvents hsp As scheduler.hsp Public WithEvents hssystem As scheduler.phone0'Event Sources End'End of automatically generated code#End RegionEnd Module
              7/14/2013 7:45:26 AM Error Script compile error: Statement is not valid in a namespace.on line 0
              7/14/2013 7:45:26 AM Event Running script in background: myAlert.vb("monitor","3@cnnbreakingnews")
              7/14/2013 7:45:26 AM Event Event Trigger "my.Alert CNN Breaking News"
              Tom
              • #22
                I apologize for not responding, I never got any alerts for new messages in this thread.
                Let me take a closer look at this, and will post a response soon (don't see anything obvious). In the meantime, can you share what version of Homeseer you are running?
                HSPRO 2.4 (ESXi 4.1) | my.Alert NEW | my.Trigger | HSTouch | ACRF2 | UltraM1G | BLWeather | BLLan | Rover
                (aka xplosiv)
                Do You Cocoon? Home Automation News, Tutorials, Reviews, Forums & Chat
                • #23
                  Thank you for your reply. Sorry I should have included this info earlier. Using HS PRO 2.5.0.52. Thank you again for your help.
                  Tom
                  • #24
                    Sorry to bother again, but I just can't get my head around this regex stuff.
                    Here are the 2 items I am missing for my weather pages.
                    Thank you,
                    Tim
                    Link -
                    http://www.wunderground.com/cgi-bin/findweather/getForecast?query=51334&sp=KIASPIRI1
                    ps - I only really need the numbers ie, 10 and 4
                    pps - I had to attach the page sources, sorry
                    • #25
                      Ok, forget that last post, I found another way.
                      I do have a question about the lake temp you worked out for me.
                      I went to the site - http://waterdata.usgs.gov/ia/nwis/uv?06604200. then opened up the ini file to look at what you did.
                      Then I looked at the page source for the website, found where you got the temp value, but this -
                      RegExSearch=instantaneous value:\s(?<temp>[0-9]{1,3}\.[0-9])\s
                      RegExReplace=temp
                      really confued me. I see nothing like that text in the page source.
                      Now the reason for all this. I now want to do the Gage Feet reading for the lake. So I thought i could figure it out from the Lake Temp entry, but I can't see how you got all those numbers and letters.
                      See below -
                      PHP Code:
                      URL=http://waterdata.usgs.gov/ia/nwis/uv?06604200
                      RegExReplace
                      =temp
                      <tr>
                      td width="35"></td>
                      td>
                      table id="table_06604200_15_00010" border="0">
                      tr>
                      td nowrap="nowrap">Most recent instantaneous value24.4 &nbsp; 08-25-2013&nbsp; 09:45 CDT </td>
                      td align="right"> </td>
                      tr>
                      tr>
                      td width="35"></td>
                      td>
                      table id="table_06604200_12_00065" border="0">
                      tr>
                      td nowrap="nowrap">Most recent instantaneous value3.90 &nbsp; 08-25-2013&nbsp; 09:45 CDT </td>
                      tr
                      Tim
                      • #26
                        If you aren't familiar with regular expressions, then my example is going to look like an Alien language for sure. Check out this website for examples/tutorials.
                        That said, let me explain the example quickly:
                        RegExSearch=instantaneous value:\s(?[0-9]{1,3}\.[0-9])\s
                        \s means a white space (such as a tab, space)
                        [0-9] means a number falling in the specified range
                        {1,3} means the previous component has to be repeated at least once, up to 3 times)
                        \. means literally a dot
                        So in this case, we are looking for a number with up to 3 digits, and 1 decimal point.
                        I'm on my phone right now, but if you still can't figure it out, post another message in this thread, and I'll create the regex once I get home.
                        (aka xplosiv)
                        • #27
                          [VB.NET] my.Alert
                          Hi Electron,
                          If you have time, could you also look at post #21 and see what the cause of these errors might be. I've re installed everything about four times and still no luck.
                          Tom
                          Sent from my iPhone
                          Tom
                          • #28
                            Thank you very much.
                            Your explanation was perfect. I was able to get it on the first try.
                            PHP Code:
                            RegExSearch=instantaneous value:\s(?<stage>[0-9]{1,3}\.[0-9][0-9])\s
                            RegExReplace
                            =stage
                            DeviceString
                            =I28
                            Content
                            =3.89
                            Tim
                            • #29
                              Hi.
                              Is posible, with this script, to scrape web pages that are generated at the client side with JavaScript (with jquery, for example).
                              If I look at the HTML source all I see is some JavaScript.
                              • #30
                                What happens when you load the JavaScript file directly? In theory, you can monitor any file, but that's assuming there isn't some other weird stuff going on.
                                (aka xplosiv)
