[VB.NET] my.Alert
    #61
    Tried a ton of things.
    Still can not get this to work.
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
      #62
      The URL is now https://waterdata.usgs.gov/usa/nwis/uv?site_no=06604200
      (https rather than http). Have you tried that?
      Jon
        #63
        Yes, tried all that already.
        It will come up as - https://waterdata.usgs.gov/ia/nwis/uv?06604200
        or ---------------- https://waterdata.usgs.gov/usa/nwis/uv?site_no=06604200
        Still get the same error.
        Tim
          #64
          This is in my ini file
          PHP Code:
          [laketemp]
          URL=https://waterdata.usgs.gov/usa/nwis/uv?site_no=06604200
          RegExSearch=Most recent instantaneous value:\s(?<temp>[0-9]{1,3}\.[0-9])\s
          RegExReplace
          =temp
          DeviceString
          =I20
          Content
          =1.5
          [lakestage]
          URL=https://waterdata.usgs.gov/ia/nwis/uv?06604200
          RegExSearch=Most recent instantaneous value:\s(?<stage>[0-9]{1,3}\.[0-9][0-9])\s
          RegExReplace
          =stage
          DeviceString
          =I28
          Content
          =4.46
          Numbers haven't changed since Dec 14th
          Tim
          Last edited by fungun; January 3, 2017, 02:06 PM. Reason: The board took out some coding
            #65
            Sorry I cannot assist further unless you move it across to HS3 and use my Datascraper....
            Jon
              #66
              Not quite ready for HS3 just yet, sorry.
              Still watching the x10 stuff get fixed up.
              But thank you for trying.
              Tim
                #67
                Well, I emailed the USGS and asked them about the error. Hereis what I got back. I went to the site they suggested, but you have to manually input the info you want.
                Don't know how that is going to work
                USGS Response:
                Dear Tim,
                I suspect your error is related to our 12/14/2016 switch to HTTPS secure protocol described in this news article:
                https://help.waterdata.usgs.gov/news...%205%2C%202016
                From the error trace it's unclear what steps might be needed. Perhaps simply changing http:// to https:// in the software or its configuration file. But it also is possible a deeper change is needed to enable HTTPS encryption (aka Secure Socket Layer, or SSL).
                Unrelated to the issue at hand, but a suggestion: you might consider https://waterservices.usgs.gov/ instead of waterdata.usgs.gov. waterservices' offers friendlier ("better", perhaps) web services for software, including several choices of output formats. But it too requires the use of the HTTPS encrypted protocol.
                Please contact me (bdgarner@usgs.gov) if you have further questions.
                Sincerely,
                Brad Garner
                Product Owner, USGS Water Data for the Nation
                Tim
                  #68
                  Well, it did work.
                  You generate a url with the info you want on their site (which is why I didn't think it would work) but I ran the url today and it does give today's date and time.
                  https://waterservices.usgs.gov/nwis/...siteStatus=all
                  I looked at the page source and it comes out like a text file.
                  PHP Code:
                  # ---------------------------------- WARNING ----------------------------------------
                  # Provisional data are subject to revision. Go to
                  # http://help.waterdata.usgs.gov/policies/provisional-data-statement for more information.
                  # File-format description:  http://help.waterdata.usgs.gov/faq/about-tab-delimited-output
                  # Automated-retrieval info: http://help.waterdata.usgs.gov/faq/automated-retrievals
                  # Contact:   gs-w_support_nwisweb@usgs.gov
                  # retrieved: 2017-01-04 12:15:26 -05:00    (natwebsdas01)
                  # Data for the following 1 site(s) are contained in this file
                  #    USGS 06604200 West Okoboji Lake at Lakeside Lab near Milford, IA
                  # TS_ID - An internal number representing a time series.
                  # Data provided for site 06604200
                  #    TS_ID       Parameter Description
                  #    44524       00010     Temperature, water, degrees Celsius
                  #    44523       00065     Gage height, feet
                  # Data-value qualification codes included in this output:
                  #     P  Provisional data subject to revision.
                  agency_cd    site_no    datetime    tz_cd    44524_00010    44524_00010_cd    44523_00065    44523_00065_cd
                  5s    15s    20d    6s    14n    10s    14n    10s
                  USGS    06604200    2017
                  -01-04 10:45    CST    1.7    P    4.53    P
                  So now how do I extract the values of "1.7" and "4.53" ?
                  Those are the Temp in C and the Stage level of the lake. I should probably get the date and time too.
                  Tim
                    #69
                    It also looks like I can output a xml file. Maybe that would be easier. (?)
                    Tim
                      #70
                      Time you ditched that old X10 stuff and moved to HS3
                      Jon
                        #71
                        Tim
                        XML is typically easy to parse. There are some great scripts floating around the forum for doing so. I think these are all written for HS3, but there may be some around for HS2 too.
                        Cheers
                        Al
                          #72
                          Ok , I looked at a few. Some are very old, like from 2004.
                          I am getting confused on the "nodes" stuff.
                          Are the "nodes" the lines you want parsed in the xml file itself?
                          If so, how am I going to get 2 values that have the same "node" name?
                          ex -
                          PHP Code:
                          <wml2:MeasurementTVP><wml2:time>2017-01-05T12:45:00-06:00</wml2:time><wml2:value>1.6</wml2:value><wml2:metadata><wml2:TVPMeasurementMetadata/>
                          wml2:MeasurementTVP><wml2:time>2017-01-05T12:45:00-06:00</wml2:time><wml2:value>4.51</wml2:value><wml2:metadata><wml2:TVPMeasurementMetadata/>
                          I need the 1.6 and 4.51 and just one of the date-time.
                          Tim
                            #73
                            ex -
                            PHP Code:
                            Tim
                            Every element in an xml is considered a node. There is an xml function that will return all the nodes with the same name as an array. Take a look at the VB examples here: https://msdn.microsoft.com/en-us/lib...code-snippet-2
                            Cheers
                            Al
                              #74
                              Well I am assuming this script works because I get no error for the script itself.
                              However I still get the same error I got from before. I won't copy the whole error, it's very long.
                              So now I am under the assumption I will have to download the xml file or the tab file and then try to parse one of them.
                              First the script, then the error.
                              Tim
                              PHP Code:
                              Imports System.XML
                              wunderground_XML.vb Pull the current temperature and wind from any of
                              '*      multiple Weather Underground stations. (version 1.0)
                              By Steve Anderson (Snevl)
                              Const lakeT_dev As String "I20"
                              'Const lakeG_dev As String = "W61"
                              Sub Main(ByVal Parms as Object)
                                  Dim lakeT as String
                              Dim lakeG as String
                                  Dim XMLdoc
                              as XMLDocument = New XMLDocument()
                              XMLdoc.Load("https://waterservices.usgs.gov/nwis/iv/?format=waterml,2.0&sites=06604200¶meterCd=00060,00065,00010&siteType=LK&siteStatus=all")
                              Dim book as XmlNode
                                      Dim root
                              as XmlNode XMLdoc.DocumentElement
                                      book
                              =root.SelectSingleNode("<wml2:value>")
                              lakeT book.InnerText
                                      hs
                              .SetDeviceString(lakeT_dev,lakeT,TRUE)
                              'book=root.SelectSingleNode("//current_observation/UV")
                              lakeG book.InnerText
                              'hs.SetDeviceString(lakeG_dev,lakeG,TRUE)
                              End Sub
                              PHP Code:
                              1/6/2017 6:14:18 PM ~!~Event~!~Running script in backgroundLakeTempStage010617.vb
                              /6/2017 6:14:21 PM ~!~Error~!~Scripting runtime errorSystem.Reflection.TargetInvocationExceptionException has been thrown by the target of an invocation. ---> System.Net.WebExceptionThe underlying connection was closedAn unexpected error occurred on a send. ---> System.IO.IOExceptionReceived an unexpected EOF or 0 bytes from the transport stream.   at System.Net.FixedSizeReader.ReadPacket(Byte[] bufferInt32 offsetInt32 count)   at System.Net.Security.SslState.StartReadFrame(Byte[] bufferInt32 readBytesAsyncProtocolRequest asyncRequest)   at System.Net.Security.SslState.Start
                                #75
                                jon00
                                So will your Datascraper get past the https or the ssl stuff?
                                Tim
