Arduino Script Testing. (Enigmatheatre)
  • It is making me feel a bit better that you're finding it strange too
    tab below:
    • Originally posted by dhalsall View Post
      tab below:
      In the event do you have a space between the comma and the dim? If so try removing it as it had to be exactly like the status pair.
      Greig.
      Sent from my SM-G925F using Tapatalk
      Scripts =
      Various
      • DOAH!
        That's it... as usual, couldn't see the forest for the trees.
        Works as expected now - lol.
        Thanks for all you help Greig!
        I'll quietly attempt to learn the rest on my own - of course, this performance hasn't filled me with self confidence... but I'll keep pluggin' away.
        dave
          DOAH!
          dave
          Good news. Glad we got there.
          I'm of to bed as it is 1.45am here and I am up at 7.[emoji17]
          Scripts =
          Various
          • wow - thanks Greig.
            Hope you work well on 5hrs sleep (I'm the same).
            • Hi Greig,
              FYI, I managed to muddle through and modify the code for my final application:
              Sub Main(parms As Object)
                      Dim tempBOX As Integer
                      Dim speedPCT As Integer
                      Dim myDevCmd As String
                      tempBOX = hs.DeviceValue(45)
                      speedPCT = (tempBOX-25)*10
                      myDevCmd = "Dim " & speedPCT & "%"
                      hs.WriteLog("BOX Cool Down", " Box Temp: " & tempBOX &"C" & " Fan Percentage: " & speedPCT)
                      CallCAPI(37, myDevCmd)
              End Sub
                  Function CallCAPI(ByVal intDevRef As Integer, ByVal strDevCmd As String) As CAPIControlResponse
                      CallCAPI = CAPIControlResponse.Indeterminate
                      For Each objCAPIControl As CAPIControl In hs.CAPIGetControl(intDevRef)
                          If LCase(objCAPIControl.Label) = LCase(strDevCmd) Then
                              CallCAPI = hs.CAPIControlHandler(objCAPIControl)
                              Exit For
                          End If
                      Next
                  End Function
              However, I have read your function over and over, and just don't get how it works! Mostly I'm sure because I have to improve my VB / scripting skills, but also, I find the references to these functions and methods in the HS3 scripting doc to be fairly vague. Is there a more in-depth resource to educate myself? Or is it just a lot of trial and error?
