Arduino Script Testing. (Enigmatheatre)
  • #31
    Originally posted by FredrikKan View Post
    ... where is the code!
    It should be available by the end of the week.
    Greig.
    Scripts =
    Various
    • #32
      • #33
        Greig.
        Fantastic news!
        Thanks!
        • #34
          Greig.
          This is very good news! Thanks for tackling this project. Did you make progress on the IP end?
          • #35
            Re: Arduino Script Testing. (Enigmatheatre)
            Sadly not yet. This has been a lot harder to do than I first thought. I have added some new features which have been causing problems and I may have to remove IR from the first release as this is the biggest problem.
            There has been a great response from the beta testers which is good news but my only problem is that I am not a programmer and have just picked up on how to do this through help from people on this board and good old Google. I hope people understand this and are not to harsh on me as I have lots of projects I would like to get out to the board but I am a little nervous about having the time to support my scripts.
            Thank you all for your time and patience on this.
            Greig.
            Sent from my Nexus 7 using Tapatalk HD
            Scripts =
            Various
            • #36
              Scripts =
              Various
              • #37
                This will open many interesting electronics project together with Homeseer, I got to try this fantastic project in its early stages and it will be exciting and try the new functions. Incredibly well done Greig.
                Tasker Plugin / Speech Droid
                Tonlof | Sweden
                • #38
                  I have used it since November. I really like it. :-)
                  Regards
                  Morten
                  • #39
                    I can also tell that Arduino works perfect with USB server over ethernet, I have my Audrino in a different building then Homeseer. http://www.silexeurope.com/en/home/p...ds-4000u2.html
                    Tonlof | Sweden
                    • #40
                      You've done a great job.
                      CONGRATULATIONS!
                      I will offer you a beer
                      thanks
                      Cristian
                      • #41
                        CONGRATULATIONS!
                        thanks
                        Cristian
                        Thanks Cristian,
                        I was getting worried as there has been 14 downloads and no comments on the script. I'm glad it is working well for you.
                        Greig.
                        Scripts =
                        Various
                        • #42
                          I think that people want a complete system, ready and immediately running .
                          Maybe there are a few users who are having fun with electronics and programming.
                          This your work is really well done, with a simple Arduino, a bit of electronics and programming can be implemented independently at least 70% of home automation products that are for sale!
                          I'm just doing experiments on breadboard, but If everything goes well, I'll have a light sensor and a rain sensor for each window, a pwm controller for strip rgb led, management of buttons, switches, relays ... all with a simple arduino mega and your plugin!
                          All this is just fantastic!
                          Cris
                          • #43
                            • #44
                              Great job!!!
                              Hi all,
                              I was so fortunate to got the beta versions of the script from Greig, and could help beta-testing the script while working on my own project.
                              With the help of Greig's script i have implemented a Arduino Mega in my heating pipe system, and now able to measure and control some pump's and valve by HomeSeer.
                              The configuration so far:
                              Arduino Mega 2560 connected to the HomeSeer PC by means of a 20 mtr USB extended cable with the following I/O:
                              5 One-wire temp sensor's
                              14 digital input's (4 used so far, other for future use)
                              1 analogue input to measure battery voltage
                              6 digital output's to control pumps and valve
                              1 LCD with RGB back-light to display temperatures
                              3 PWM outputs to control the RGB back-light of the display
                              After a lot of time testing on the breadboard, i have now finished implementing everything in the 'real world'!!!
                              Greig has done a GREAT job with his script, everything is working as expected and i am very happy with his work, it's opening a lot of interesting possibilities to connect other equipment to HomeSeer.
                              Ok , you have to like 'tinkering' with electronics, but then with this script there are possibilities you can't get with the normal X10 and Z-wave equipment i have used so far.
                              Thanks Greig, job well done!!!!
                              • #45
                                How do I add 1-wire?
                                Hi Greig! Having no luck with my breadboard version of the mailbox setup (the inputs I defined does not trigger on 5v - will make another try later) I went on with other experimenting;
                                Today I tried to add a 1-wire temperature sensor with no success;
                                • I deleted an input device earlier defined in HS on pin 10
                                • shutted down HS
                                • edited the Homeseer VX.X.X.ino to use 1-wire on pin 10 (and deleted the old usage for pin 10)
                                • loaded the new code to Arduino
                                • physically added the 1-wire sensor to the board
                                • restarted HS and clicked "Setup" button for the board device
                                No new 1-wire device shows up under devices. What device code will it use - could it be a collision with an already used device code?
