Originally posted by FredrikKan
View Post
Hi FredikKan,
Maybe i can help.
If a "new" one-wire sensor is connected it will first show-up in the arduino.ini (located in the config section of HS), a new entry with the ROM adress of the sensor is added (like 289DA4A53005=HC) you have to change 'HC' into the housecode you want it to be in HS.
When the arduino.ini is saved, the script in HS will create the new device.
This is also explained in Greig's script manual.
Regards, Peet
