I relooked into your wonderful plugin after running some long network cable for a greenhouse 1-wire network and have to say it is working fantastically. I have a number of different 1-wire sensors, one before and one after a heat exchanger, one in a electronics box, and another in the greenhouse itself, so i can turn on or off the heat exchanger based on the greenhouse temperature, and or the temperature coming in and out of the heat exchanger (e.g. is the heat ex-changer absorbing heat).
I did have a feature request though (if i could make one). Although the accuracy of some of the 1-wire sensors is not great, it would be fantastic if the measurement was not rounded, e.g. you multiply the reading (stored as the device value) by 100 or 1000 to represent the decimal values, that way when you work with the reading you can just divide by 100 or whatever number to have the full decimal number for temperature.
Thanks for the great Script!
