TextSeer (and WPseer) discussion
  • TextSeer (and WPseer) discussion
    This is where to discusss TextSeer and WPseer.
    Here's the HS3 version: http://board.homeseer.com/showthread.php?p=1122376
    Is there any ability to toggle a device rather than just turn on or off.
    I'm looking to embed a url in an RFID tag and use my Lumia 920 (WP8) to toggle devices on/off.
    Also the ability to trigger events would be great too...
    If possible I'd like to have a look at integrating RFID into the WPSeer app if you could share the code for it??
      A toggle for on/off and dimmable devices is a great idea! And should be easy to implement aswell.
      Send me an email, and I'll see if I can dig up the source.
        Thanks for making the HS3 version available Moskus, it works great!
        Cheers
        Al
          Not a problem! I kind of had to, I was depending on it myself...
            Did you ever implement a toggle function?
              Yeah, but I haven't gotten around to publish it yet, I'll do that this weekend.
                Awesome. Thanks!
                  Have you been able to add the possiblity to run an event with textseer?
                    Yes... that too needs to be in the new version.
                      See version 0.0.2
                      ... I can't remember if it includes toggle (I seldom use toggle), but it can trigger events.
                        Nice, whats the event command? Doesnt say so in the help file.
                        Cant find the toggle command in 0.0.2?
                          ... no, sadly, there's no toggle yet.
                          I remember now, I made a script for it but didn't add it to the plugin yet.
                          For events, try this:
                          To see all event groups
                          /textseer?Location1=[Events]
                          To see all events in a group:
                          /textseer?location1=[Events]&location2=Kontroll
                          From there, just grab the Event ID, and execute it like you would with a device but with the command "Run Event":
                          /textseer?deviceid=1000&devicecmd=Run%20Event
                            Textseer - Cool - Documentation??
                            I just discovered Textseer and it works pretty cool. I know I could control HS3 with JSON but it is way more complex than necessary.
                            Is there any one place to see all of the URL options? I have gathered up some of the things from various posts so I can control devices and trigger events.
                            In particular I would like to trigger an event and pass a parameter.
                            Thanks.
                              Events does not take parameters, so that's not possible.
                              If you mean scripts, however, I think I can add that.
                              I'll write out all the different URL commands.
