i put the .DLL file like described. stopped HS and started HS again. But i can't find it. have i forgot something here?
Pushover (3P) Plugin
Originally posted by U5tabil View Posti put the .DLL file like described. stopped HS and started HS again. But i can't find it. have i forgot something here?
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
Pushover all log entries for specific plugin
This is a great plugin. I was wondering if there is some way to push over all log entries for a specific plugs (like envisalink). I'd like to see all my alarm activity and this would seem a good way to do it. I can make it work now on individual zones, but I'd like to see all envisalink activity sent to pushover?
Originally posted by jterfehr2000 View PostThis is a great plugin. I was wondering if there is some way to push over all log entries for a specific plugs (like envisalink). I'd like to see all my alarm activity and this would seem a good way to do it. I can make it work now on individual zones, but I'd like to see all envisalink activity sent to pushover?
Originally posted by michganblue82 View PostGood morning,
Only some of my push notifications are working. I have the same parameters set for different events, and the logs show the events are running, just not notifications. Any information would be much appreciated:
If the first one is disabled you only get emergency notifications, if the second one is disabled you will not get any. That is the only thing I can think of. My notifications have been flawless for a couple of years.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostMake sure both of the devices below are enabled:
[ATTACH]60799[/ATTACH]
Pushover 3P: Unknown Exception in Pushmessage: Object reference not set to an instance of an object.
Been digging in these forums and can't find anything that solves it...any additional suggestions?
Originally posted by michganblue82 View PostI have all of these as optioned replicated but getting the following error:
The only thing that jumps out at the minute is your selection of devices to send the message to, I've never thought of it but I'm not sure how the plugin responds when you try and send to All Clients and also the iPhone as well. If you select All Clients alone does it behave any differently? Also check you are running the latest version in the updater.
Originally posted by mrhappy View PostSorry I didn't see this post to start with, this is the thread for the HS2 plugin and I'm no longer subscribed to it so I missed this.
Originally posted by michganblue82 View PostYOU'RE A HERO! Thanks!! I only checked the iphone instead of all devices and it seems to be working.
Thanks for spotting it, must've been in there a while!!
Originally posted by mrhappy View PostThat's good to hear thanks, I've put a little fix in for this for when the next release of the plugin comes out. If you tick all clients and another value then it will just send it to all of the clients.
Pushover errors when sending and no sound options.
Hello, I've been happily using the pushover plugin on HS2 for a few years not without any trouble but recently noticed that I was getting errors in the log whenever I send a push message....
Pushover (3P) Error Error POST URL: Object reference not set to an instance of an object.
It goes through but with the default sound.
I went into one of my events and noticed the "Select message sound" dropdown has not sounds to select from. I think this might be the issue.
I noticed the plugin shows version 0.0.0.3 and I tried upgrading it in the updater but it doesn't show the plugin in the list of updates.
I am currently on HS2 Professional Edition 2.5.0.80
Do you happen to have the updated files you could post here?
Originally posted by tommyd75 View PostHello, I've been happily using the pushover plugin on HS2 for a few years not without any trouble but recently noticed that I was getting errors in the log whenever I send a push message....
Unfortunately I have not looked at the HS2 code in a very long time and I neither have a HS2 setup or the time to install a testing environment and update the HS2 code for the few users that are going to be left using it. As such I'm afraid I'd have to consider the HS2 plugin largely broken at this point. The HS2 plugin release was not in the updater which is why you can't see it there. Sorry I can't be of much more help, the only option I can consider is looking at whether you can find a script on the forum (I think there is one) to send messages.
