I would like to replace the strMode with a variable that I pass thru the script ("main", "Test") How do I put the variable in the message field? Right now the strMode will not be replaced by Test but as strmode.
sub main(ByVal strMode As String)
Dim InpStr As String = hs.getURL("http://test.com&message=strMode&pass...word","",False, 80)
hs.WriteLog("Debug",strMode)
End Sub
Thank you for your help
End Sub
