XML HTTP RESTful API for HS3 - Discussion Thread
  • XML HTTP RESTful API for HS3 - Discussion Thread
    This thread is the support/discussion thread for the RESTful API I created for HomeSeer 3, located in this thread: http://board.homeseer.com/showthread...20#post1089120
    Please post any issues, questions, complaints, or compliments in this thread.
    Thanks Everyone!
    Hi. I installed your plugin but i am having no luck getting any commands to go through. I am able to execute an event, but only when using a browser on the same computer that HS3 is on.
    I use this command:
    http://192.168.1.102:86/HomeSeer_RES...&param1=Garage Door Toggle
    Im guessing I need to put my user name/password in there. How do I do this so I can fire events from other computers on my lan, and most importantly to enable events from remote computers?
    Something like?:
    https://chris:xxx71536@192.168.1.102...&param1=Garage Door Toggle
    I feel I'm missing something obvious.
      AWESOME!
      Hi Red, this is an awesome script. I have been using it now for a week or two.
      One question/thought. This seems perfect for using as a more general web service into Homeseer. In particular to use for Occupancy for when you are at home. I found an iOS app called Geo Hopper that allows you to do geofencing (GPS) and iBeacons (bluetooth) that are both good on battery life. It allows the use of web hooks.
      I made an HS Device called Bill is At Home that is turned off an on by an Event (which nicely enough can be triggered by a URL using your API
      I setup geo hopper to do a POST to this URL:
      http://myserver/HomeSeerAPI.aspx?fun...am1=BillIsHome
      Unfortunately it doesn't seem to trigger the URL via Geohopper. Is this because your API works only on a GET using that URL and not a POST? Or is there something wrong with geo hopper?
      Also it would be great if we could extend your script to take in custom POSTs with data like the below. A reference example would be good, otherwise I will have to brush off my comp sci programming skills.
      PHP Code:
      http://geohopper.com/support
      What information gets sent to the web service? ∞
      When a web service is notifiedit sends a HTTP POST to the specified URL.  It posts a JSON payload:
      "sender":"tperfitt@twocanoes.com","location":"Beacon in upstairs office","event":"LocationExit","time":"2013-09-11 02:03:33 +0000"}
      The fields are defined as follows:
      SenderThe email address of the sender.
      LocationThe name of the defined location that triggered the event.
      EventThe type of event.  Possible values are LocationEnterLocationExitLocationTest
      Time
      time the event occurred in RFC 3339 format
        I use this command:
        Something like?:
        Bandook, when you browse to the URL in your browser it will prompt you for your HomeSeer Username and Password via Basic Auth (Same as if you were browsing to it via a computer on your LAN). You could pass the credentials in the URL like you described, If you want to automate a URL call.
        Are you getting any sort of error or is it just timing out? Are you sure you are using the correct port and protocol (http/https) that Homeseer's web interface is running on?
        Are you able to access HomeSeer's Web UI at all for a LAN computer? You might need to enable a Admin + Local account in homeseer.
          PHP Code:
          Time
          Robilium, unfortunately the API currently only supports HTTP GET verbs. I will definitely look into adding the ability to pass the variables via POST calls as well.
          What you could do is write a simple PHP (or other language of your choice) script that will accept the post calls from Geohopper and then make the GET call into the Homeseer REST API. A sort of interface API, if you will.
          That would also be the best practice anyway. That way if say something changes with the REST API down the road, all you have to do on your end is change your interface API without having to change anything else in Geohopper or any other software package that would make calls into the REST API.
            Cool thanks.
            It seems like PHP isn't installed as part of the HomeSeer install
            So I assume I would have to go figure out C# like you are using or VB scripting...
              Cool thanks.
              Ah yes, if you wanted to use the HomeSeer's web server then yes you would nee to use C#.NET or VB.NET.
              But if you have a few spare cycles I would highly recommend XAMPP. I have it installed on the same server as HomeSeer (running on a different port of course). It is a packaged Apache Web Server, MySQL and PHP solution for Windows. http://www.apachefriends.org/en/xampp.html
              I use XAMPP for my Adobe Air application that uses PHP as a backend that communicates into this API via PHP HTTP CURL calls.
                Thank you! I was indeed missing the obvious. I just installed hs3 on my server and forgot to change firewall rules.
                Your program works great! Using it on my android phone through tasker for beautiful one click events. One thing I would like is to have a way to toggle devices on/off. Is there a toggle command for homeseer?
                Thanks again!
                Chris
                  Thank you! This is exactly what I've been looking for.
                  Haven't had a chance to do anything cool with it yet, but hopefully this weekend I'll have some time!
                    Thanks again!
                    Chris
                    You can set a device to on / off using the "Set Device Status (By ID or Name)" cmd. You don't need events for that!
                    You could easily build an interface API (a separate php or C# script) that toggles. Basically you would build a condition that uses "Get Device Status" then based on the result of that cmd use "Set Device Status" to the opposite value.
                      Awesome! Glad, you are enjoying it! Let me know how it works out!
                        Thanks. Well, I'm trying. Wondering if you could get me over a hump. This is my very first script, ever. Having a lot of fun learning Python, but am pretty stuck. I'm unable to get the "status" into eventghost. What I'm trying is this:
                        import eg
                        import urllib2
                        eg.RegisterPlugin()
                        class MyNewPlugin(eg.PluginBase):
                        def __init__(self):
                        self.AddAction(HallLightOn)
                        self.AddAction(HallLightOff)
                        class HallLightOn(eg.ActionBase):
                        def __call__(self):
                        response = urllib2.urlopen('http://192.168.1.102:86/HomeSeer_REST_API.aspx?function=devicestatusbyid&param1=2036&param2=on')
                        if response.read == 'true':
                        print "true"
                        What I'm hung up on is that I can't get (response.read) to provide me anything that I can use as a variable. I can get it to print out in eventghost log as "true" or "false", but using it in my "if" statement it wont work. Just confuses me. It returns true when the light on, but using that in my code as a condition does nothing in Eventghost. It Shows my action has ran, and I get no errors, but I just want it to print something so I can then finish the code as I know its then working.
                        Hope I made sense. My brain feels like cotton right now, lol. Thanks for any help. Once I get it to respond I can finish what I'm doing fairly easily, I think.
                          import eg
                          import urllib2
                          eg.RegisterPlugin()
                          def __init__(self):
                          def __call__(self):
                          print "true"
                          Hmm, not to familiar with Python, but have you tried:
                          PHP Code:
                          if response.read == 'True'
                          Difference being a capital "T" for true? Not sure if it's choking on the case sensitivity.
                          But if you call my API:
                          That is working?
                            That doesn't work either, but thanks for the shot in the dark
                            Yeah, your API works great. I can just do "print response.read()"
                            And it will log true/false. Just cant figure out why I can't capture the response and use it. I asked for some help over on the Eventghost forums, which is where I should have asked. Your side works great, its just my noobishness that's frustrating me.
                              Just to update and bring some conclusion to my issue, it was indeed a simple error. I just needed this:
                              if response.read() == 'True':
                              So now I am able to toggle my device with one action in eventghost with:
                                response = urllib2.urlopen(getstatus)
                                          urllib2.urlopen(turnoffdevice)
                                      else:
                                       urllib2.urlopen(turnondevice)
                              Eventually I'll finish the plugin and enable you to enter each device you want to control in the plugin config, and create actions for each device. Shouldn't be crazy hard but my learning curve is steep so it will take me awhile.
