How do I get script copy - Solved!
  • How do I get script copy - Solved!
    I assumed that the "Script Library" was where I might find copies of various scripts. However, I see nothing when I open it. I am looking for the iPhone portrait version of Weather5dayRSS.xml for HSTouch. Where might I find that?
    HS3Pro on Windows 10
    One install with 2 Ethernet Z-nets
    2nd install with 1 Zstick
    300 devices, 250 events, 8 scripts
    5 CT-100 tstats
    Serial IT-100 interface to DSC Panel with 8 wired zones
    18 Fortrezz water sensors & two valve controls
    Serial Rain8Net Pro with 8 zones
    So when you click on the script library you see no posts?
    http://board.homeseer.com/forumdisplay.php?f=631
    -Rupp
      The iPhone project (unless it has changed in HS3) is an all in one project which has only the one project xml file so AFAIK the weather screen is just part of this one file. There is a version on the message board if you click downloads on the bar in the forum and there is a projects section however I think that project is a bit old now.
        Whoops...
        Sorry, I unwittingly was set to see only today's posts...
        5 CT-100 tstats
