I am not going to try to say this script is pretty or even well written, but thought some others might be interested in it anyway.
Basically, this is a vb script called with 2 parameters:
- the first is the case sensitive location
- the second is True if you want it to speak the actions taken
One note, this script looks for Device Types with specific keyword in that string to determine if they are a switch/light or something else like a thermostat. You may need to update that near line 31 or so.
If anyone want to clean it up some or add other features, I am cool with that...just repost your code for others.
Sub Main(ByVal Parms As object) '*** Off by Location script '*** Version 1.00 - Mike Israels 'Parameter 0 - Location2 value, case sensitive 'Parameter 1 - if True, script will speak actions when turning off a light Dim ParmArray() as String ParmArray = parms.tostring.split(",") Dim loc = ParmArray(0) Dim speak = ParmArray(1) Dim logName = "Off by Loc" Dim debug = False Dim dev_switch as Boolean Dim isOffCAPI as Boolean Dim CallCAPI, dv, dev_type, dev_stat Dim intValue, intDevRef, objDev, devName Dim en = hs.GetDeviceEnumerator hs.writelog (logName, "Checking for any lights that are not OFF for location2= " & loc & ", Speak= " & speak) Do dv = EN.GetNext If dv Is Nothing Then Continue Do if dv.Location2(nothing) = loc then intDevRef = dv.ref(nothing) devName = dv.Location2(nothing) & " " & dv.Location(nothing) & " " & dv.Name(nothing) dev_type = dv.Device_Type_String(nothing) ' --- check to see if the device type contains some word that makes us realize it is a switch of sorts dev_switch = False if dev_type.contains("Switch") or dev_type.contains("Dimmer") or dev_type.contains("LampLinc") then dev_switch = True if debug then hs.writelog (logName, devName & " is a Switch") else if debug then hs.writelog (logName, devName & " is NOT a Switch") end if intValue = hs.DeviceValueEx(intDevRef) objDev = hs.GetDevicebyRef(intDevRef) '--- check to see if the device is off only if it is a switch if dev_switch = True then IsOffCAPI = False For Each objCAPIControl As CAPIControl In hs.CAPIGetControl(intDevRef) If intValue = objCAPIControl.ControlValue Then If LCase(objCAPIControl.Label) = "off" Then IsOffCAPI = True End If Exit For End If Next if IsOffCAPI then if debug then hs.writelog (logName, devName & " is already OFF") else hs.writelog (logName, devName & " is not off...sending OFF command.") if speak="True" then hs.speak ("Turning off " & devName) '--- turn the device off CallCAPI = CAPIControlResponse.Indeterminate For Each objCAPIControl As CAPIControl In hs.CAPIGetControl(intDevRef) If LCase(objCAPIControl.Label) = "off" Then CallCAPI = hs.CAPIControlHandler(objCAPIControl) Exit For End If Next end if 'if IsOffCAPI end if 'if dev_switch end if 'if dv.Location2 Loop Until EN.Finished End Sub
