Can not control simple device using 'Immidiate Script Command'
    I am experimenting how to control one of my devices using the 'Immidiate Script Command'-function in HS2 (and in a later stadium put these lines in a script).
    When I put the text <!--StartFragment -->{&hs.SetDeviceStatus "[1", on} (without {/}) in the textbox and I click the 'Execute command'-button, an error like 'running script; init errir: syntaxisfout' appears.
    When i put in the text {&hs.SetDeviceStatus "[1", off}, I don't get an error, but nothing happend as well.
    Can someone please tell me what i'm doing wrong?
    Is this HS3? If so it's a known issue. Bug 1949. Add your name to it and it might get some attention.
    Originally posted by rprade
      No, it's on HS2....
        Setdevicestatus only accepts 2,3,4 and 17 for second parameter. IIRC 2 is on,3 is off, 4 is dim and 17 is unknown.
