IP / Serial Plugin for HS3 (by "drule") - Discussion Thread
    Found the examples above
    Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
      Great.
      cheeryfool
        working on Sony. can anyone toss a couple of examples to get me started ?
          Geary
          What model Sony TV are you trying to control?
          Cheers
          James
          cheeryfool
            will check tonite .. 55" XBR LCD
            You two have done an outstanding job on this plug-in too bad is it obscure in finding.. you would have many more users.. maybe you need to charge a few bucks or get it listed in the plug-in section
              well.... not quite there yet w/ Samsung
              see error..
              could it be because I am connected via another plug-in ?
                see error..
                All the Samsungs that I have or have heard about, cannot directly be controlled by pinging commands at them over IP. That's why we need Dirk's plugin (which you have) to control them once they're on, with the ugly Sammy protocol.
                The main problem with Samsung TVs is turning them on as they don't respond to the RJ45 port when switched off.
                This leaves you two options, IR (which we're all trying to avoid) and Serial over the RS232 "Exlink" port. My Exlink ports are all 3.5mm stereo jacks and I have a custom DB9 -> stereo cable that David built for me. In fact, it's 2 custom cables. 3.5mm to RJ45 [then a home run Cat6] then RJ45 to DB9, which for good measure I then have going into a serial server. All of this just to turn on the TV without IR!
                cheeryfool
                  well... Lucky that the Sony in my Living Room is more important to control
                  I have that connected thru serial from a GC-100-6
                  I will re-hook up my GC tonight. I was running a serial emulator pkg before, will I still need it ?
                    Did you figure out the commands from the spec sheet you poster earlier, or you had that one working previously?
                    cheeryfool
                      never worked... a "project" in process...
                        You won't need the serial emulator pkg. Just send the commands to port 4999 on the GC-100-6 and they'll go to its serial port.
                        -David
                          like this ??
                            like this ??
                            Yes.
                              how about a sample command to turn the tv on / off ?
                              Won't get a chance to try until Monday..
                                and here we go....
