IP / Serial Plugin for HS3 (by "drule") - Discussion Thread
    Hi David,
    Did you get my PM ?
    Best regards,
    Fischi
      New version posted here
      Fixes a bug that was causing the plugin to attempt to read data from a tcp host connection after the remote client had closed the connection.
      cheeryfool
        Originally posted by Fischi View Post
        Hi David,
        Did you get my PM ?
        Best regards,
        Fischi
        I've just emailed you something to try.
          eth484 inputs are working fine.
          But I also want to operate the relay with an device.
          So I created an device with 2 script buttons.
          I assume I have to add a new connection for the eth484 and make it a client? (eth484_1_R)
          Then in the script on an ON command from the device it is executing this:
          hs.PluginFunction("drhsIpPlugin", "", "Ext_Send_Data", New Object() {"eth484_1_R", "0x20 0x01", "Binary"})
          But the relay does not go ON.
          What am I doing wrong?
          Found the problem. Had to add the time for pulsed output, so 0x20 0x01 0x00 is the right code to set the relay.
          Peter
          http://ohh.pcgsm.nl
            Originally posted by drule View Post
            Now there's an interesting question! The very early version of this plugin was a simple tcp host that listened for strings. I wrote it for the purpose of being able to send "commands" from iRule into HS but tried to keep it generic enough so that it might be useful for other things too.
            Initially I was using it to send strings such as "iRule00" & "iRule01" to HS, which would then trigger events. That event might have multiple actions, eg., turn the TV on, dim the lights, change the input on my HDMI switch, etc.. I'm a big Insteon user so I would probably use the term "scene" to describe my HS events.
            At first, I had HS control everything. I view it as a Rosetta Stone of home automation. I didn't use iRule to change channel on the TV for instance, because HS could already do that for me and why configure something twice? However, over time I keep changing my mind back and forth on that one :-) iRule is better at somethings than HS so why not have it do them? So what I've ended up with is a mishmash, an ever changing mishmash. For instance, on my main TV I have a Sonos playbar. iRule's Sonos plugin isn't to my liking but dcorsus's Sonos plugin for HS is superb. Therefore I have an iRule button than sends a string to HS, which triggers an event to control the Sonos volume via dorcus's plugin.
            As far sending stuff back to iRule from HS, my initial thought was to use an HS event triggered by say a light switch changing dim level, to send data to an iRule feedback construct. Unfortunately, I haven't had the time to fully implement it in my own iRule setup and consequently I suspect that there's a bunch of fine-tuning required that I haven't yet seen. I welcome other people's thoughts and observations on how this can be improved.
            So, sorry but I haven't really answered your question about a recommended approach!
            -David
            Good news...
            Have Created a Device & Feedbacks in iRule and it's working well with your terrific plugin and Homeseer. Lights switching on off and dimming, SONOS messages flying around! It's good!
            One little question...right now, to parse inbound messages, I have created a script which I have attached to the connection. I think, for cleanliness, I'd rather attach a script to the "Received Trigger" event, but it demands a "String Received" -- and since I don't know what the string received will be...it doesn't work! Is there a wildcard one can enter into this field (I tried *, - doesnt work!). Alternately, would you consider adding a trigger (say, Connection Message Trigger) that didn't need a "String Received" parameter, and passed the same array of parameters into the params object as you do when we run a script attached to a connection?
            Not that big a deal I suppose, but would be cool.
            Attached is an iRule screenshot!
              Originally posted by skavan View Post
              Good news...
              That is a very nice iRule layout. Far better than anything I have ever built! Congrats
              cheeryfool
                Thanks...what I lack in homeseer smarts, I make up for in Photoshop!
                  Great, glad you got it working :-)
                  -David
                    A very nice iRule layout indeed.
                    OK, I've added a Connection Message Trigger as you suggested, to trigger an event whenever data is received, regardless of content. I've also added a corresponding "send data to script" action, that will send the last data received by a connection to the specified script with the same parameter object format as a pass-thru script. The two can be used independently or together.
                    PM me your email address and I'll send you the new version to test before it gets posted on here.
                    Cheers
                    -David
                      Cheers
                      -David
                      very cool. will do and thanks.
                      s.
                        Hi David,
                        I've just seen that you are online.
                        Did you get my latest PM ?
                        Fischi
                          Hi David,
                          Fischi
                          Just catching up after a few days away. You're next on my list! ;-)
                            I really wanna try this and see if I can send serial commands from my URC remotes to homeseer. It looks like the INI file is missing from the zip but the EXE file is there...tks
                            HSPro on a Supermicro Atom|Z-Net
                            Elo touchscreen client, Android Phones and Tablets, Xbox One
                            Global Cach/Ultra-GCIR | Etherrain | Jon00 | Sonos | Blue Iris | URC Whole Home Remotes | Philips Hue | Nest | Grandstream | Leviton | Aeon Labs | Cooper | Kwikset | Evolve | Envisalink/DSC | Amazon Alexa/IFTT
                              The INI file will generate when you create your connections and commands. I used to include an old version of mine along with the EXE, but stopped doing that. I can send you a version if you want to see how it would look with my config, but give it a shot setting things up anyway.
                              cheeryfool
                                Ok I'll check it out...thanks
