Contacting HomeSeer This Week
See more
See less
IP / Serial Plugin for HS3 (by "drule") - Discussion Thread
  • #16
    I followed the instructions to instal the plugin and placed the ini file here"C:\Program Files\HomeSeer HS3\Data" but there are no commands that show up under the command tab.
    • #17
      It should be in the config folder.
      Cheers
      Al
      • #18
        Thanks. That's what it was. Another question how do I configure the connections. the ones in the example are to connect to a serial server. I run a Hometroller and the HDMI matrix is connected to com port 2 on the back of the Hometroller.
        • #19
          Great. For the serial port config, see post #14 above. For you, select serial and type in 2 in the address.
          Cheers
          Al
          • #20
            Thanks for your help I got it working. Is there a way to do status tracking in HSTouch. I have a screen with 8 buttons. 1 for -A1,A2 etc.. I want to light up the button that correspond with the status of the HDMI matrix.
            • #21
              That's a jolly good question! Unfortunately I don't have HSTouch, so I'm not entirely sure how to do it, or what changes I'd need to make to the plugin to get it to work that way. Happy to try though!
              There is an event action "Send status/value". This sends the current status or value of any Homeseer device over a connector to whatever might be listening on the other end. Right now I have been using this to send 'feedbacks' to iRule running on my iPad. In principle I think this is the same thing as status tracking in HSTouch. iRule feedbacks let me for instance, show bright/dim levels of my lights on my iRule pages. It's still a bit of a work in process as I haven't fully decided how I want this feature to end up, so there's scope for incorporating any suggestions.
              -David
              • #22
                David
                Is there a simple way to read the feedback/status from the matrix either in to global variables or virtual devices that might help freeon?
                cheeryfool
                • #23
                  Originally posted by cheeryfool View Post
                  David
                  Should be doable via a pass-thru script. Can i assume you are referring to the Monoprice HDMI matrix switch? If so, I'll try to dig mine out this weekend and I'll post a quick sample script that should do most of what you're after.
                  -David
                  P.S.
                  I'm not currently planning on updating my HS2 plugin for Monoprice switches to HS3 but beer might help to persuade me otherwise. ;-)
                  • #24
                    I was really just looking for solutions to freeon's question, though I will probably want to do this myself with my Monoprice HDMI matrix too.
                    If we can get similar functionality from the IP/Serial plugin (even using scripts) then IMHO leave the matrix plugin as HS2 only.
                    cheeryfool
                    • #25
                      The HDMI matrix is what I want to track but if it works and if could also work for my TV's connected via serial cable that would be nice.
                      • #26
                        Any idea were I can get the codes for my Panasonic TV and Projector
                        • #27
                          Drule. What's your favorite beer?
                          _______________________________________________
                          HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
                          Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
                          Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
                          • #28
                            I don't have any questions yet since I just downloaded the new version, just wanted to send a big THANK YOU! I almost got the old version working with my extron matrix, could send commands, but not get status updates, but hopefully with the new version it will be easier. Thank you again for your continued work on this plugin!
                            OK... one quick question... I have a 16X16 Audio Matrix, 8X8 DVI matrix, and 4X4 HDMI matrix so typing out each command could get a bit clunky. Is there a limit on the number of commands that can be in the plugin? I am not sure if I should figure out a way to pass a variable into the script instead of setting each command.
                            • #29
                              I started work on this. Watch this space...
                              -David
                              • #30
                                You're very welcome! There have been a few delays in releases this year as I've been travelling a lot for my day job. Cheeryfool is currently testing the next beta and hopefully it will be uploaded soon. After it's been in the wild for a week or two, I think I'll change the version number to 1.0 (or maybe 3.0) and call it released.
                                There is no limit to the number of commands you can define but a script would be an elegant solution.
                                -David
