IP / Serial Plugin for HS3 (by "drule") - Discussion Thread
UPDATE: Got it all working now :-) - Thanks for your help.
Hi drule,
can you maybe send me your ini file, I am having a hard time finding out how to send to the units with or without scripts:-)
Best regards MartinLast edited by twister5800; February 4, 2016, 02:15 AM.
Sending socket message back
Hello,
I have a tcp device talking to HS3 via drhsIpPlugin.
I want to be able to respond to incoming messages via the tcp connection
I see you need a script to do this, thus I have ... HouseStatus.vb, see below. I thought the "Ext_Send_Command" line would send a text value back to the sending client, in this case the one I have called RemoteFob.
Is this the correct way to send a packet back to the incoming connection?
Also is there any API documentation, that would help please...
John
Sub Main(param() As Object)
Dim ConnectionName As String = param(0)
Dim FromIp As String = param(1)
Dim AsciiData As String = param(2)
hs.WriteLog("Pass-thru 0", ConnectionName)
hs.WriteLog("Pass-thru 1", FromIp)
hs.WriteLog("Pass-thru 2", AsciiData)
hs.PluginFunction("drhsIpPlugin", "", "Ext_Send_Command", New Object() {"RemoteFob", "Test Command"})
End Sub
John
End Sub
-David
OK. Thanks Al.
So now on to the meat of all this. I am trying to send a UDP command across the LAN and I don't have the foggiest idea of how to make it work. There is apparently no documentation? I'm trying to send anything at all to 192.168.1.145:3333.
Help?Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Help?
Cheers
AlHS 3.0.0.548: 1990 Devices 1172 Events
Z-Wave 3.0.1.262: 126 Nodes on one Z-Net
Originally posted by sparkman View PostNo problem. It's been a while since I played with it as I' m currently not using it. You need to add a connection on the Connections page. The entries there should be pretty self-explanatory. Then on the Commands page, define something that you want to send. Once that's done, create an event and there will be options for drhsIpPlugin listed as one of the actions. Pick the one related to sending a command and then pick the connection and command you want to send. HTH.
Cheers
Al
Great. You've got me heading in the right direction. On the connections tab what are Multicast Group, Proxy and Script? I filled out the Name, Type, Host/Client and Port fields but when I go to create an event the connection dropdown has nothing in it.... ?Do I need to restart the plugin or something?
Originally posted by S-F View PostGreat. You've got me heading in the right direction. On the connections tab what are Multicast Group, Proxy and Script? I filled out the Name, Type, Host/Client and Port fields but when I go to create an event the connection dropdown has nothing in it.... ?Do I need to restart the plugin or something?
Cheers
Originally posted by sparkman View PostNot sure what those are for. Have never used them and don't believe they need to be filled out. The ones you did fill out are the only ones you should need. Did you also create a Command on the Commands tab? I just tried it and did not have to restart the plugin. Which version of the plugin are you using? I have 0.0.0.21.
Cheers
Al
I got it! Had it set to host not client. Woops.
Thanks for getting me on my feet! here! Cool plugin. Documentation would be key though.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
I'm seeing an enormous amount of these errors:
<table class="log_table_row" cellspacing="0"><tbody><tr><td class="LogType0" colspan="3" align="left">drhsIpPlugIn </td><td class="LogEntry0" colspan="8" align="left"> Method Capabilities does not exist in this plugin. </td></tr></tbody></table><table class="log_table_row" cellspacing="0"><tbody><tr><td class="LogType1" colspan="3" align="left">
</td><td class="LogEntry1" colspan="8" align="left">
</td></tr></tbody></table>Am I doing something wrong?Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Example for iRule integration
Hi:
Love the plugin: works great to control all my AV equipment through a couple of GC100s via both serial and IP.
Now I'd like to integrate iRule, with its lovely interface, as the front end of HS. But for the life of me I can't find a clear description anywhere of exactly how to set up the receiver connection: what settings should I use for the commands? What address and port should I use for the connection? And is it possible to test from a mobile browser instead of having to resync an iRule handset?
A simple example, perhaps with screenshots, would do the trick, I'm sure. Or just a description. Whatever you can muster is greatly appreciated.
Thanks again for a great plugin.
I haven't seen those before, so drule will need to comment.
Cheers
Al
Sent from my iPhone using TapatalkHS 3.0.0.548: 1990 Devices 1172 Events
