Here are screenshots to illustrate what I'm talking about
IP / Serial Plugin for HS3 (by "drule") - Discussion Thread
v28 bug fix for serial connections that didn't show up as triggers.
v28 fixes a bug that prevented serial connections from showing up as triggers
https://forums.homeseer.com/showthre...17#post1132517cheeryfool
USB to Serial?
I'm moving from a windows PC w/ serial ports & HS to a new win7 PC with no serial ports and HS3. With the new PC/HS3 I am using a Keyspan USB2Serial adaptor to communicate with a serial UPB PIM. With the old PC, I've been sending RS232 to Qmotion blinds (QConnect transmitter) from HS2 with scripting to the serial ports. Could I could use this plugin to send serial commands to the QConnect over another Keyspan USB2Serial adaptor?
Originally posted by Jayhawk View PostI'm moving from a windows PC w/ serial ports & HS to a new win7 PC with no serial ports and HS3. With the new PC/HS3 I am using a Keyspan USB2Serial adaptor to communicate with a serial UPB PIM. With the old PC, I've been sending RS232 to Qmotion blinds (QConnect transmitter) from HS2 with scripting to the serial ports. Could I could use this plugin to send serial commands to the QConnect over another Keyspan USB2Serial adaptor?
Originally posted by drule View PostThat's a good idea. I'll look into it for the next release.HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
...why UDP ???
@Krumpy, thanks for the suggestions.
As we are making a good progress towards the new universal communication plug-in code named "Big4" I was wondering if we need to include UDP + multi-casting.
Can you please give examples of devices and or practical situations that will benefit from that.
How can you see the GC-100 Serial Ports in IP/Serial Plugin for HS3
I've searched the forums and a couple PM's to drule.. And I've got this plugin up and running. I've successfully added a Denon 3808ci via TCP/IP, figured out the command structure ( PWON\r) as C escaped . All works. Working on the response status for Serial commands, but thats another issue.
Currently, I was expecting first off the GC PRO plugin I just spent $$ in hopes it would control ALL functions not just IR and Relay. I knew this plugin should per what post I read be able to control the GC-100 Serial Ports, but I never see the Serial Tab show up. I am using the HS2 Pi on a HomeTroller, understand I can by a USB to Serial adapter, but it was the reason why I grabbed a cheap GC-100 for all of those functions in one.
What I am missing? Only see TCP/IP, I have added the GC-100-12 to the connections...but no serial ports to config, etc.
Any help would be greatly appreciated....
Thanks ,
KeyMix
Current Date/Time: 12/11/2017 7:03:49 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.368
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 0 Days 1 Hour 19 Minutes 56 Seconds
IP Address: 192.168.1.64
Number of Devices: 10
Number of Events: 5
Available Threads: 393
Enabled Plug-Ins
2.0.45.0: BLDenon
0.0.0.28: drhsIpPlugIn
5.0.0.58: Global Cache Pro
3.0.0.28: MediaController
3.0.1.130: Z-Wave
Originally posted by drule View PostI have a GC-100-18 and am successfully using its serial port with the plugin. Use the web interface of the GC-100 to set the serial port's parameters, ie baud rate, start/stop bits, etc. Then in the plugin, create a TCP client pointing to the IP address of your GC-100, port 4999.
-David
Originally posted by KeyMix View PostThanks David, I think my main issue is there is no Serial Tab shown. I am using a HomeTroller and not using PC HS3, just the HS3pi on the HomeTroller. I was assuming before I added the GC-100 that I would see the Serial Tab to show up after a device that had serial ports was added to the HomeTroller. I am currently not using any USB to Serial Adapter nor did I think i need to since my desire was to use the GC-100 for IR and Serial.
