IP / Serial Plugin for HS3 (by "drule") - Discussion Thread
    Originally posted by drule View Post
    This might be enough but I'm concerned that Homeseer event will get to the last data received/script action before your device has had the chance to respond. You might need to insert a wait action in-between the last send command and the send to script action.
    -David
    I just restarted the HS, everything was fine. I also removed the "Send Data To Script".
    des-28 23.08.01	 	Pass-thru	Volume set to : -3.00 A
    des-28 23.08.01	 	Pass-thru	Connection to : ClearOne PSR1212
    des-28 23.08.01	 	drhsIpPlugIn	Sending 15 bytes to ClearOne PSR1212
    des-28 23.08.01	 	drhsIpPlugIn	Sending 4 bytes to ClearOne PSR1212
    des-28 23.08.01	 	Event	Event Trigger "Test Druletest"
    des-28 23.08.01	 	Event	Event Test Druletest triggered by the event page 'Run' button.
    This is the log now, after some editing of the script.
    Thanks a lot to pointing me in the right direction.
      Good news!
        New questtion :
        How can I use hs.pluginfunction and callback ?
          Hello,
          I have a small problem with the plugin. Version 0.30
          I have an Yeelight Wifi StripLed
          after a while, the connections are no longer active.
          I must resend the event.
          The yeelight stripLed is always on network
          My command:
          Power OFF : --> {"id": 2, "method": "set_power", "params": ["off", "smooth", 500]}\r\n
          Power ON : --> {"id":1,"method":"set_power","params":["on","smooth",500]}\r\n
          Set Scene type 4-7-8 --> {"id":1,"method":"set_scene","params":["cf",100,1,"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1"]}\r\n
          Set Scene type Police: --> {"id":1,"method":"set_scene","params":["cf",0,0,"300,1,16711680,1,50,1,222,1,50,1,3355647,100,50,1, 222,1,50,1,16711680,100,50,1,222,1,50,1,3355647,100,50,1,222 ,1"]}\r\n
          My connection ( see screen shot)
          Yesterday, i have created some command, and Ini file is miscompleted.
          At startup, i have this log:
          My Ini File :
          [Settings]
          open=checked
          [Connections]
          Yeelight Discover=Host,UDP,,1982,,Passthru.vb,0,239.255.255.250,<N/A>
          AVR_3313=Client,TCP,192.168.xx.22,23,,AVR3313.vb,1,,<N/A>
          Yeelight-1=Client,TCP,192.168.xx.33,55443,,Passthru.vb,1,,<N/A>
          [Commands]
          PioAVR Pwr Off=C Escaped,PWSTANDBY\r
          PioAVR Pwr On=C Escaped,PWON\r
          PAPP T1=C Escaped,Reset
          Yeelight-1 Power ON=C Escaped,{"id":1,"method":"set_power","params":["on","smooth",500]}\r\n
          Yeelight-1 Power OFF=C Escaped,{"id": 2, "method": "set_power", "params": ["off", "smooth", 500]}\r\n
          Yeelight set_ct_abx=C Escaped,{"id":5,"method":"set_ct_abx","params":[1700, "smooth", 500]}\r\n
          Yeelight set_rgb=C Escaped,{"id":3,"method":"set_rgb","params":[65536, "smooth", 500]}\r\n
          Yeelight set_HUE=C Escaped,{"id":4,"method":"set_hsv","params":[1, 100, "smooth", 500]}\r\n
          Test PWR TW7300=C Escaped,45 53 43 2F 56 50 2E 6E 65 74 10 03 0d
          New command-cd91=
          Yeelight Start_Cf=
          New command-53ce=
          Yeelight Stop_Cf=C Escaped,{"id": 2, "method": "stop_cf", "params": []}\r\n
          Yeelight Mode Bougie=C Escaped,{"id":3,"method":"start_cf","params":[ 0,0,800,2,2700,50,800,2,2700,30,1600,2,2700,80,800,2,2700,60 ,1200,2,2700,90,2400,2,2700,50,1200,2,2700,80,800,2,2700,60, 400,2,2700,70"]}\r\n
          New command-a16b=
          Test Flow=C Escaped,{"id":1,"method":"start_cf","params":[ 0,1,"300,1,16711680,50,4000,7,0,0,300,1,16776960,50,7000,7,0 ,0,300,1,16711935,50, 8000,7,0,0"]}\r\n
          New command-732b=
          Yeelight Set_scene Police=C Escaped,{"id":1,"method":"set_scene","params":["cf",0,0,"300,1,16711680,1,50,1,222,1,50,1,3355647,100,50,1, 222,1,50,1,16711680,100,50,1,222,1,50,1,3355647,100,50,1,222 ,1"]}\r\n
          New command-3c6f=
          Yeelight 4-7-8 mode=C Escaped,{"id":1,"method":"set_scene","params":["cf",100,1,"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1"]}\r\n
          Jean-Francois
            Originally posted by jfla View Post
            Hello,
            My command:
            My Ini File :
            Jean-Francois
            Not sure how those corrupted commands came to be in your ini file but I would manually delete them for now and restart the plugin.
            I've had a quick look at the yeelight documentation and I think you are doing everything right. Does the disconnect occur on a regular basis? If so, I'm wondering if the yeelight is timing out the persistent connection. If we can determine how long it is before the timeout, we might be able to craft some sort of keep-alive routine.
            -David
              New questtion :
              Is this what you are looking for?
              hs.PluginFunction("drhsIpPlugin", "", "Ext_Send_Command", New Object(){"Test Connection", "Test Command"})
              hs.PluginFunction("drhsIpPlugin", "", "Ext_Send_Data", New Object(){"Test Connection", "Hello\sworld\r\n", "C Escaped"})
              “Ext_Send_Command” will send the predefined command, eg “Test Command”, to the connection “Test Connection”.
              “Ext_Send_Data” will send a string, eg "Hello\sworld\r\n", parsed as either “URL-Encoded, Raw Test, Binary or C Escaped”, to the connection “Test Connection”.
                Solved...
                Maybe... but how can I implement that in the callback script ?
                  I'm not sure I understand what you are trying to do. Can you give me some more detail?
                    On last question, I suddenly realise that is the connection which have the callback script, not the code :
                    How can I connect to a IR port on a GC-12, or Itach IP2IR, for sending IR to a Matrix. I also see that some are getting feedback from IR. Howto ?
                      You can send IR codes to a GC-12 or iTach from an Event. In the plugin config, configure your global cache device as a TCP client and in the IR commands tab, enter IR codes in Pronto Hex format. When you create an event, you can choose which IR LED to send the code to.
Name:	Screen Shot 2018-01-01 at 1.24.30 PM.jpg
                      Event:
Name:	Screen Shot 2018-01-01 at 1.22.46 PM.jpg
                      The plugin can receive IR commands from a GC-IRE or GC-IRL
Name:	Screen Shot 2018-01-01 at 1.20.47 PM.jpg
                      -David
                        So not possible to send IR Command via scripting ?
                          You can send Global Cache sendir strings via scripting but not direct IR commands. So if you had connections and commands like:
Name:	Screen Shot 2018-01-01 at 1.43.22 PM.jpg
Name:	Screen Shot 2018-01-01 at 1.39.42 PM.jpg
                          You could send it from a script:
                          hs.PluginFunction("drhsIpPlugin", "", "Ext_Send_Command", New Object(){"GC-100-18R", "DirecTV - 0 (IR)"})
                          This works in the current version. I will add a new function "Ext_Send_IR_Command" for direct IR scripting, to a future version of the plugin.
                          -David
                              v31 sent to cheeryfool for uploading. Only change is the inclusion of a new external scripting command "Ext_Send_IR_Command". The syntax is:
                              'hs.PluginFunction("drhsIpPlugin", "", "Ext_Send_IR_Command", New Object(){Connection, Type, IR Code, LED, Repeat Count})
                              ' for example:
                              hs.PluginFunction("drhsIpPlugin", "", "Ext_Send_IR_Command", New Object(){"GC-100-12", "Global cache", "DTV_1_Select", "4:1", "2"})
                                ' for example:
                                v31 uploaded
                                cheeryfool
