Clarification on Plugin Commands from script and feedback
I posted this question earlier (Post #658),
I have a Denon 3808ci that I am accessing via IP control. Thru these threads, I used a simple script ( below) from this thread to get the Denon Responses from my commands requesting status ( power status, input status, volume etc) successfully, and then posts that response to the log in HS3. Perfect that worked!!
Public Sub Main(Param() As Object)
hs.WriteLog("drhsIpPlugin", Param(2).ToString)
End Sub
However, I am still trying to gain some clarification on the scripting with this plugin in terms of the commands/syntax.
I am assuming I can via the plugin commands add the required lines to take that same response and send it to a global Variable ( String I assume). With the goal in mind to then be able to use that data to show device status on a virtual device or be able to recall that string via HStouch, etc.. I am not connecting the dots from the HS3 help and the syntax used
. Any suggestions or relevant posts I may have missed? Again Great Plugin..
End Sub
