Originally posted by BJB
View Post
IP / Serial Plugin for HS3 (by "drule") - Discussion Thread
Made those changes but no luck so far. Adding the x0x just added more hex Numbers to the group in front. When trying to get the terminal software to work on this board, it started working when picking the option: "Parse XXHEX CODES" . Maby there is a comand to add that here. Thank you for looking at it, I will search the previous examples as you suggested.
Originally posted by BJB View PostMade those changes but no luck so far. Adding the x0x just added more hex Numbers to the group in front. When trying to get the terminal software to work on this board, it started working when picking the option: "Parse XXHEX CODES" . Maby there is a comand to add that here. Thank you for looking at it, I will search the previous examples as you suggested.
F = 46 in hex....
Verstuurd vanaf mijn SM-G935F met Tapatalk
Well, just finished going back over this entire 739 postto try and make sure the problem i'm having is not already discussed and resolved, but was not able to find anything.
I have a 8 relay board as shown in https://forums.homeseer.com/forum/ho...rd-with-hs3pro
Just trying to operate the relays, Post #734 is the screen shots of where I'm at now trying to operate the first relay, if you can help resolve i sure would appreciate it.
Originally posted by BJB View PostWell, just finished going back over this entire 739 postto try and make sure the problem i'm having is not already discussed and resolved, but was not able to find anything.
Just trying to operate the relays, Post #734 is the screen shots of where I'm at now trying to operate the first relay, if you can help resolve i sure would appreciate it.HS 3.0.0.548: 1990 Devices 1172 Events
When I was experimenting I realize now that keeping records is important. Most of the trials were before I had the program that lets me see what information is being sent, so I will try again some of the other types to see what happens. What I have seen so far is if I add a "," or "\n" or "\r" that the list of numbers to the left is just added too. I believe peterpc said that its the HEX equivalent being sent. I can't find a command to make that list not be sent.
Originally posted by BJB View PostWhen I was experimenting I realize now that keeping records is important. Most of the trials were before I had the program that lets me see what information is being sent, so I will try again some of the other types to see what happens. What I have seen so far is if I add a "," or "\n" or "\r" that the list of numbers to the left is just added too. I believe peterpc said that its the HEX equivalent being sent. I can't find a command to make that list not be sent.HS 3.0.0.548: 1990 Devices 1172 Events
I maybe have a related problem that someone knows a fast answer to?
I am bridging between VeraPlus and HS3 with this plugin triggering events on raw text messages received over tcp.
I get the impression that sometimes the plugin does not flush out the triggering text properly or fast enough and I thereby get double events or/and lost events.
Question: should the raw text be terminated in some way? With a CR or CRLF?
The problem could be on the sender side as well where I use this code:
Code:function VeraAlert(host, port, Msg) local socket = require("socket") local tcp = socket.tcp() tcp:settimeout(3) if (tcp:connect(host, port)) then if (tcp:send(Msg)) then else luup.log("Error Sending Msg") end else luup.log("Error Opening Socket") end tcp:close(socket) end VeraAlert("192.1.1.120", 6000, "MyMsg")
Hi,
First time user of this plug-in. I'm wondering how do I display the data received by the plug-in into a script? I see that here is an event action for doing this, but how should the script look that receives the data? My goal is to have a script that parse the data string received and based on the data trigger events.
Code:Sub Main(Param() as Object) hs.writelog("irule connector",Param(0).ToString) hs.writelog("irule ip address",Param(1).ToString) hs.writelog("irule data",Param(2).ToString) End Sub
Hello,
I am unsure on how to install this plugin. I'm migrating network resources from Universal Devices ISY and this seems to be the plugin needed. I reached out to HS support and they said they are unsure on how to install and reach out here. Can someone please advise me? I appreciate the help.
Thank you!
Maybe im doing something wrong with the updater_overrride.txt file. Running windows 10.
Code:%<HS TYPE=SUBCAT>Test Plugin ' ------------------------------------------------------------- drhsIpPlugIn31.zip, HSPI_drhsIpPlugIn.exe, ,31, 63, 2, local,, drhsIpPlugIn31.zip, 4, Free, HomeSeer Tech, X10, http://homeseer.com/updates3/icons/X10.gif, http://homeseer.com/updates3/descriptions/X10.htm,,
