ok, sorry about the long delay in getting back on this one. I had to move the whole Homeseer setup over to my new server under Windows 10 and debug everything that didn't work after doing this. I got everything stable, and started looking into this again. I added the new version of the plugin and created the pass-thru script.
I issued a play command to the device and then grabbed the homeseer and drhsplugin log information from the command. Not sure if this helps?
Feb-13 20:39:07 Pass-thru There are 4095 bytes of binary data.
Feb-13 20:39:07 Pass-thru AsciiData
Feb-13 20:39:07 Pass-thru FromIp
Feb-13 20:39:07 Pass-thru ConnectionName
Feb-13 20:39:06 Error 3 Running script Russound_MPX_2_Incoming.vb :Exception has been thrown by the target of an invocation.->Does entry point Main exist in script? at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Obj ect obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at Scheduler.clsRunVBNetScript.ExecuteScript()
Feb-13 20:39:06 Pass-thru There are 4095 bytes of binary data.
Feb-13 20:39:06 Pass-thru AsciiData
Feb-13 20:39:06 Pass-thru FromIp
Feb-13 20:39:06 Pass-thru ConnectionName
Feb-13 20:39:06 Event Event Trigger "Security - General Whole House Motion Triggered | Delete delayed events - Arm Away | Lock all Doors | Turn Stereo Off"
Feb-13 20:39:06 drhsIpPlugIn Sending 32 bytes to Russound-CHA3
Feb-13 20:39:06 drhsIpPlugIn Sending 14 bytes to Russound-CHA2
Feb-13 20:39:06 drhsIpPlugIn Sending 14 bytes to Russound-CHA3
Feb-13 20:39:06 MPX_Out Player: MPX-1 | Command: PLAY
Feb-13 20:39:06 Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/Russound_MPX_Outgoing.vb("Main","MPX-1|PLAY")
Feb-13 20:39:06 Event Event Trigger "Audio/Video - MPX MPX-1 Outgoing SCRIPT - PLAY"
Feb-13 20:39:06 Event Event Audio/Video - MPX MPX-1 Outgoing SCRIPT - PLAY triggered by the event page 'Run' button.
2/13/2021 8:39:06 PM:
Sub Main()
Dim AsciiData As String = "S
N S[1].name="Media Streamer"
N S[1].type="Russound Media Streamer"
N S[1].Support.favoritesV2="TRUE"
N S[1].Support.MM.longList="TRUE"
N S[1].Support.MM.restoreOption="TRUE"
N S[1].Support.availableControls="TRUE"
N S[1].Support.trackTime="TRUE"
N S[1].Support.playTime="TRUE"
N S[1].Support.playerData="TRUE"
N S[1].channelName="033 1st Wave"
N S[1].coverArtURL=""
N S[1].channelArtURL="http://pri.art.prod.streaming.siriusxm.com/images/channel/20180725/firstwave-1-31-00-180x180.png"
N S[1].mode="SiriusXM"
N S[1].shuffleMode=""
N S[1].repeatMode=""
N S[1].volume="0"
N S[1].rating="UNKNOWN"
N S[1].playlistName="Rock"
N S[1].artistName="Saturday Night"
N S[1].albumName=""
N S[1].songName="Safety Dance"
N S[1].availableControls="{"contextMenu":false,"dislike":false,"li ke":false,"next":false,"pause":false,"play":true,"previous ": false,"repeat":false,"seekBack":false,"seekForward":false,"s eekTime":false,"seekTrack":false,"shuffle":false,"stop":true }"
N S[1].trackTime=""
N S[1].playTime="1928"
N S[1].playerData="{"breadCrumbs":"","mimeType":2186088,"mode":5," playId":"","rootPath":"0","title":"Rock","type":"","url":{"c ontrol":"play","mediaRoles":{"audioType":"audioBroadcast","c ontext":{},"description":"Classic Alternative","icon":"http://pri.art.prod.streaming.siriusxm.com/images/channel/20180725/firstwave-1-31-00-180x180.png","id":"033","mediaData":{"metaData":{"contentPla yContextPath":"sirius
layContext?name=1st%20Wave&siriusChannelNo=33&id=firstwave&g enre=rock","genre":"Rock","live":true,"playLogicPath":"siriu s:/PlayLogic","serviceID":"sirius"},"resources":[{"httpTimeout":120,"mimeType":"audio/mp4","uri":"http://localhost:8080/api/stream/sirius:firstwave;goLive"}]},"path":"sirius:firstwave","title":"033 1st Wave","type":"audio"}},"useUrl":true}"
N S[1].sampleRate="44100"
N S[1].bitDepth="32"
N S[1].bitRate="256001"
N S[1].format="MPEG-4 AAC"
N S[1].playStatus="playing"
S"
Dim BinaryData() As Byte = {83, 13, 10, 78, 32, 83, 91, 49, 93, 46, 110, 97, 109, 101, 61, 34, 77, 101, 100, 105, 97, 32, 83, 116, 114, 101, 97, 109, 101, 114, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 116, 121, 112, 101, 61, 34, 82, 117, 115, 115, 111, 117, 110, 100, 32, 77, 101, 100, 105, 97, 32, 83, 116, 114, 101, 97, 109, 101, 114, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 83, 117, 112, 112, 111, 114, 116, 46, 102, 97, 118, 111, 114, 105, 116, 101, 115, 86, 50, 61, 34, 84, 82, 85, 69, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 83, 117, 112, 112, 111, 114, 116, 46, 77, 77, 46, 108, 111, 110, 103, 76, 105, 115, 116, 61, 34, 84, 82, 85, 69, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 83, 117, 112, 112, 111, 114, 116, 46, 77, 77, 46, 114, 101, 115, 116, 111, 114, 101, 79, 112, 116, 105, 111, 110, 61, 34, 84, 82, 85, 69, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 83, 117, 112, 112, 111, 114, 116, 46, 97, 118, 97, 105, 108, 97, 98, 108, 101, 67, 111, 110, 116, 114, 111, 108, 115, 61, 34, 84, 82, 85, 69, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 83, 117, 112, 112, 111, 114, 116, 46, 116, 114, 97, 99, 107, 84, 105, 109, 101, 61, 34, 84, 82, 85, 69, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 83, 117, 112, 112, 111, 114, 116, 46, 112, 108, 97, 121, 84, 105, 109, 101, 61, 34, 84, 82, 85, 69, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 83, 117, 112, 112, 111, 114, 116, 46, 112, 108, 97, 121, 101, 114, 68, 97, 116, 97, 61, 34, 84, 82, 85, 69, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 99, 104, 97, 110, 110, 101, 108, 78, 97, 109, 101, 61, 34, 48, 51, 51, 32, 32, 49, 115, 116, 32, 87, 97, 118, 101, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 99, 111, 118, 101, 114, 65, 114, 116, 85, 82, 76, 61, 34, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 99, 104, 97, 110, 110, 101, 108, 65, 114, 116, 85, 82, 76, 61, 34, 104, 116, 116, 112, 58, 47, 47, 112, 114, 105, 46, 97, 114, 116, 46, 112, 114, 111, 100, 46, 115, 116, 114, 101, 97, 109, 105, 110, 103, 46, 115, 105, 114, 105, 117, 115, 120, 109, 46, 99, 111, 109, 47, 105, 109, 97, 103, 101, 115, 47, 99, 104, 97, 110, 110, 101, 108, 47, 50, 48, 49, 56, 48, 55, 50, 53, 47, 102, 105, 114, 115, 116, 119, 97, 118, 101, 45, 49, 45, 51, 49, 45, 48, 48, 45, 49, 56, 48, 120, 49, 56, 48, 46, 112, 110, 103, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 109, 111, 100, 101, 61, 34, 83, 105, 114, 105, 117, 115, 88, 77, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 115, 104, 117, 102, 102, 108, 101, 77, 111, 100, 101, 61, 34, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 114, 101, 112, 101, 97, 116, 77, 111, 100, 101, 61, 34, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 118, 111, 108, 117, 109, 101, 61, 34, 48, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 114, 97, 116, 105, 110, 103, 61, 34, 85, 78, 75, 78, 79, 87, 78, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 112, 108, 97, 121, 108, 105, 115, 116, 78, 97, 109, 101, 61, 34, 82, 111, 99, 107, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 97, 114, 116, 105, 115, 116, 78, 97, 109, 101, 61, 34, 83, 97, 116, 117, 114, 100, 97, 121, 32, 78, 105, 103, 104, 116, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 97, 108, 98, 117, 109, 78, 97, 109, 101, 61, 34, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 115, 111, 110, 103, 78, 97, 109, 101, 61, 34, 83, 97, 102, 101, 116, 121, 32, 68, 97, 110, 99, 101, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 97, 118, 97, 105, 108, 97, 98, 108, 101, 67, 111, 110, 116, 114, 111, 108, 115, 61, 34, 123, 34, 99, 111, 110, 116, 101, 120, 116, 77, 101, 110, 117, 34, 58, 102, 97, 108, 115, 101, 44, 34, 100, 105, 115, 108, 105, 107, 101, 34, 58, 102, 97, 108, 115, 101, 44, 34, 108, 105, 107, 101, 34, 58, 102, 97, 108, 115, 101, 44, 34, 110, 101, 120, 116, 34, 58, 102, 97, 108, 115, 101, 44, 34, 112, 97, 117, 115, 101, 34, 58, 102, 97, 108, 115, 101, 44, 34, 112, 108, 97, 121, 34, 58, 116, 114, 117, 101, 44, 34, 112, 114, 101, 118, 105, 111, 117, 115, 34, 58, 102, 97, 108, 115, 101, 44, 34, 114, 101, 112, 101, 97, 116, 34, 58, 102, 97, 108, 115, 101, 44, 34, 115, 101, 101, 107, 66, 97, 99, 107, 34, 58, 102, 97, 108, 115, 101, 44, 34, 115, 101, 101, 107, 70, 111, 114, 119, 97, 114, 100, 34, 58, 102, 97, 108, 115, 101, 44, 34, 115, 101, 101, 107, 84, 105, 109, 101, 34, 58, 102, 97, 108, 115, 101, 44, 34, 115, 101, 101, 107, 84, 114, 97, 99, 107, 34, 58, 102, 97, 108, 115, 101, 44, 34, 115, 104, 117, 102, 102, 108, 101, 34, 58, 102, 97, 108, 115, 101, 44, 34, 115, 116, 111, 112, 34, 58, 116, 114, 117, 101, 125, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 116, 114, 97, 99, 107, 84, 105, 109, 101, 61, 34, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 112, 108, 97, 121, 84, 105, 109, 101, 61, 34, 49, 57, 50, 56, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 112, 108, 97, 121, 101, 114, 68, 97, 116, 97, 61, 34, 123, 34, 98, 114, 101, 97, 100, 67, 114, 117, 109, 98, 115, 34, 58, 34, 34, 44, 34, 109, 105, 109, 101, 84, 121, 112, 101, 34, 58, 50, 49, 56, 54, 48, 56, 56, 44, 34, 109, 111, 100, 101, 34, 58, 53, 44, 34, 112, 108, 97, 121, 73, 100, 34, 58, 34, 34, 44, 34, 114, 111, 111, 116, 80, 97, 116, 104, 34, 58, 34, 48, 34, 44, 34, 116, 105, 116, 108, 101, 34, 58, 34, 82, 111, 99, 107, 34, 44, 34, 116, 121, 112, 101, 34, 58, 34, 34, 44, 34, 117, 114, 108, 34, 58, 123, 34, 99, 111, 110, 116, 114, 111, 108, 34, 58, 34, 112, 108, 97, 121, 34, 44, 34, 109, 101, 100, 105, 97, 82, 111, 108, 101, 115, 34, 58, 123, 34, 97, 117, 100, 105, 111, 84, 121, 112, 101, 34, 58, 34, 97, 117, 100, 105, 111, 66, 114, 111, 97, 100, 99, 97, 115, 116, 34, 44, 34, 99, 111, 110, 116, 101, 120, 116, 34, 58, 123, 125, 44, 34, 100, 101, 115, 99, 114, 105, 112, 116, 105, 111, 110, 34, 58, 34, 67, 108, 97, 115, 115, 105, 99, 32, 65, 108, 116, 101, 114, 110, 97, 116, 105, 118, 101, 34, 44, 34, 105, 99, 111, 110, 34, 58, 34, 104, 116, 116, 112, 58, 47, 47, 112, 114, 105, 46, 97, 114, 116, 46, 112, 114, 111, 100, 46, 115, 116, 114, 101, 97, 109, 105, 110, 103, 46, 115, 105, 114, 105, 117, 115, 120, 109, 46, 99, 111, 109, 47, 105, 109, 97, 103, 101, 115, 47, 99, 104, 97, 110, 110, 101, 108, 47, 50, 48, 49, 56, 48, 55, 50, 53, 47, 102, 105, 114, 115, 116, 119, 97, 118, 101, 45, 49, 45, 51, 49, 45, 48, 48, 45, 49, 56, 48, 120, 49, 56, 48, 46, 112, 110, 103, 34, 44, 34, 105, 100, 34, 58, 34, 48, 51, 51, 34, 44, 34, 109, 101, 100, 105, 97, 68, 97, 116, 97, 34, 58, 123, 34, 109, 101, 116, 97, 68, 97, 116, 97, 34, 58, 123, 34, 99, 111, 110, 116, 101, 110, 116, 80, 108, 97, 121, 67, 111, 110, 116, 101, 120, 116, 80, 97, 116, 104, 34, 58, 34, 115, 105, 114, 105, 117, 115, 58, 112, 108, 97, 121, 67, 111, 110, 116, 101, 120, 116, 63, 110, 97, 109, 101, 61, 49, 115, 116, 37, 50, 48, 87, 97, 118, 101, 38, 115, 105, 114, 105, 117, 115, 67, 104, 97, 110, 110, 101, 108, 78, 111, 61, 51, 51, 38, 105, 100, 61, 102, 105, 114, 115, 116, 119, 97, 118, 101, 38, 103, 101, 110, 114, 101, 61, 114, 111, 99, 107, 34, 44, 34, 103, 101, 110, 114, 101, 34, 58, 34, 82, 111, 99, 107, 34, 44, 34, 108, 105, 118, 101, 34, 58, 116, 114, 117, 101, 44, 34, 112, 108, 97, 121, 76, 111, 103, 105, 99, 80, 97, 116, 104, 34, 58, 34, 115, 105, 114, 105, 117, 115, 58, 47, 80, 108, 97, 121, 76, 111, 103, 105, 99, 34, 44, 34, 115, 101, 114, 118, 105, 99, 101, 73, 68, 34, 58, 34, 115, 105, 114, 105, 117, 115, 34, 125, 44, 34, 114, 101, 115, 111, 117, 114, 99, 101, 115, 34, 58, 91, 123, 34, 104, 116, 116, 112, 84, 105, 109, 101, 111, 117, 116, 34, 58, 49, 50, 48, 44, 34, 109, 105, 109, 101, 84, 121, 112, 101, 34, 58, 34, 97, 117, 100, 105, 111, 47, 109, 112, 52, 34, 44, 34, 117, 114, 105, 34, 58, 34, 104, 116, 116, 112, 58, 47, 47, 108, 111, 99, 97, 108, 104, 111, 115, 116, 58, 56, 48, 56, 48, 47, 97, 112, 105, 47, 115, 116, 114, 101, 97, 109, 47, 115, 105, 114, 105, 117, 115, 58, 102, 105, 114, 115, 116, 119, 97, 118, 101, 59, 103, 111, 76, 105, 118, 101, 34, 125, 93, 125, 44, 34, 112, 97, 116, 104, 34, 58, 34, 115, 105, 114, 105, 117, 115, 58, 102, 105, 114, 115, 116, 119, 97, 118, 101, 34, 44, 34, 116, 105, 116, 108, 101, 34, 58, 34, 48, 51, 51, 32, 32, 49, 115, 116, 32, 87, 97, 118, 101, 34, 44, 34, 116, 121, 112, 101, 34, 58, 34, 97, 117, 100, 105, 111, 34, 125, 125, 44, 34, 117, 115, 101, 85, 114, 108, 34, 58, 116, 114, 117, 101, 125, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 115, 97, 109, 112, 108, 101, 82, 97, 116, 101, 61, 34, 52, 52, 49, 48, 48, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 98, 105, 116, 68, 101, 112, 116, 104, 61, 34, 51, 50, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 98, 105, 116, 82, 97, 116, 101, 61, 34, 50, 53, 54, 48, 48, 49, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 102, 111, 114, 109, 97, 116, 61, 34, 77, 80, 69, 71, 45, 52, 32, 65, 65, 67, 34, 13, 10, 78, 32, 83, 91, 49, 93, 46, 112, 108, 97, 121, 83, 116, 97, 116, 117, 115, 61, 34, 112, 108, 97, 121, 105, 110, 103, 34, 13, 10, 83, 13, 10}
Dim ObjectArray(3) As Object
ObjectArray(0) = "Russound-CHA3"
ObjectArray(1) = "192.168.2.192:9621"
ObjectArray(2) = AsciiData
ObjectArray(3) = BinaryData
hs.RunScriptFunc("Russound_MPX_1_Incoming.vb", "Main", ObjectArray, False, False)
End Sub
Sub Main()
N S[1].volume="0"
N S[1].albumName=""
N S[1].trackTime=""
S"
End Sub
