Heatmiser NEO Thermostat Plug-In Beta
    Update: This plug-in is now being released as finished product to the updater. I have removed the beta version from this post.
    Updated to beta version 3.0.0.4
    Attached you'll find a zip file with a beta version of a plug-in that allows control of Heatmiser NEO thermostats via the Heatmiser NEO hub.
    Install it in one of two ways:
    Either:
    1) Copy the .EXE and .DLL from the zip file to your HS3 directory
    2) Go to the Plugins/Manage page and enable the plug-in
    Or:
    1) Copy the updater_override.txt file to your HS3 directory
    2) Go to the Plugins/Manage page and click "Update Listing" under Additional Interfaces
    3) Select the NEO plug-in from the list, download and install as you would a normal plug-in
    4) enable the plug-in
    Once the plug-in is running, go to the Plug-ins/Heatmiser NEO/Config page and setup the IP address for the NEO hub.
    At present the plug-in includes lots of functionality for temperature, set points, hold mode, lock including schedules (comfort levels).
    Feedback from anyone willing to test this plug-in would be most welcome.
    Once this is finalised it will be released to the HS3 updater as a paid plug-in
    Nicolai L
