Enable or Disable an Event Plugin
    Thought I'd post this simple plugin I wrote for myself in case it could be useful for anybody else. This plugin lets you enable or disable HomeSeer Events from an Event. Hopefully it is fairly self explanatory from this screenshot.
    During testing I found that the plugin does not function correctly on HS 3.0.0.96, because of a HomeSeer bug (http://bugzilla.homeseer.com/bugzill...ug.cgi?id=1439). However it works perfectly on 3.0.0.143 and above, both Windows & Linux.
    To install, unzip the drhsEventEnabler.exe file and copy it to your HomeSeer directory. Then on the Plugins/Manage page, enable drhsEventEnabler.
    Cheers
    -David
    HSPI_drhs_EventEnabler.zip
    Would it be possible to allow this to disable the event it is being called in? I would like to disable some events after they are run.
      There is a scripting command that will disable an event.
      You could try including an immediate script command [ &hs.DisableEvent "<event name>" ] as the last event action, after a wait of a second or two. I've never tried to disable a running event that way, but it might work.
      If it doesn't, you could try having the event run another event that has the immediate script command action.
        I did try that as immediate script without a delay and it didn't work. I loaded up the easy trigger plugin and I could disable the running event.
          Hello,
          I have an event which is manually run and which I normally run from another event, but which I want to disable.
          I noticed when the event is disabled ( via this plugin or with the &hs.DisableEvent "event name"), it is still runs when the other event "runs" the disabled event. Is there a way to disable an event, so even when being run from another event it wont run.
          Cor
            The easiest way I've found is, instead of disabling the event, create a virtual device that you turn on (or off) when you do not want the event to run. Add a condition to the event that the device is off (or on). Then, in the calling event select the advanced icon and choose 'Run only when conditions are true'
              Thanks Uncle Michael . Nice simple solution. From a completely different angle - just set a flag! You opened my eyes.
              Last edited by HouseholdGeek; May 17, 2020, 06:41 PM. Reason: credit where it's due.
