THIS PLUGIN IS NOT FINISHED/FULLY FUNCTIONAL YET!
I've been working on and off on this plugin for some time and haven't quite found the time to finish it off. However, a couple of people have expressed an interest in seeing where I have got to so far, so I'm posting this as an early/test release.
Right now the plugin can read data from the thermostat, including Heat & Cool Setpoints, Room Temperature and Operating Mode. You can create events that trigger according to these values. However, you cannot currently make changes to the thermostat from Homeseer. I've tested doing this in some separate code and hope to add this functionality to the plugin soon.
This plugin is intended to interface with Bryant Evolution and Carrier Infinity "Connex" thermostats. These thermostats communicate with webservers at either www.myevolution.bryant.com or www.myinfinity.carrier.com. Since my system is a Bryant, that is the only system I have been able to test with so far. If you have any other thermostat type, I have no idea if it will work or not but I'm happy to help if I can.
For this plugin to operate you do not need to have a System Access Module (SAM) and do not need to make any physical connections to your furnace. However, the myevolution/mycarrier web service should be enabled and running.
The plugin works by acting as a web proxy for the thermostat. Traffic between the thermostat and the web service is captured sent to Homeseer for processing.
To start, unzip drhsEvolution.exe from the attached zip file and copy it to your HS3 directory. Now you should see "drhsEvolution" listed on the interfaces page and can start it.
By default the plugin will listen for connections on port 8081. You can change this in the plugin's config page if required.
Next you will need to configure your thermostat to use a web proxy to communicate with the web service.
Select "wireless" from the thermostat's menu:
Then "Wi-Fi setup":
Then "advanced settings":
And finally "proxy settings":
Here you will need to enter the ip address of your HS3 server and change the proxy port to 08081. On my system I found that entering the FQDN instead of the ip address did not work. YMMV.
The thermostat should attempt to communicate with the web service approximately once a minute. The first time the plugin sees traffic from a thermostat it will create appropriate Homeseer devices automatically. If you don't see any devices created within a minute or two, check these settings and also check that Windows Firewall, or iptables, isn't blocking port 8081.
Chances are that you are going to want to send me some debug info if you run into any difficulties using this plugin. If so, on the plugin's config page there is an option to enable enhanced debugging. When this is enabled, a log file of web traffic between the thermostat and the web service is written to drhsEvolution.txt in the HS3/Logs directory. Please be ready to send me parts of this log. :-)
-David
Discussion thread is located here:
http://board.homeseer.com/showthread...47#post1163747
Version 0.0.0.2: (changes to proxy timings)
Version 0.0.0.3: (more proxy changes, additional png files, handle some extra messages)
Version 0.0.0.4: (not released)
Version 0.0.0.5: (interim test release, can now change heat/cool setpoints and operating mode)
[ATTACH]n1271486[/ATTACH]
Then "Wi-Fi setup":
-David
