Discussion thread for Bryant Evolution / Carrier Infinity Plugin
Hi David,
I just loaded your plugin, Thanks for the work on this.
It created the devices, but does not seam to update them.
All setpoints are at 0, and activity is away, and mode is OFF.
I presume it has communication as the devices did get created, correct?
I attached the log for you
I am also missing the .png's for the Activity, Mode Status, and Thermostat Mode.Attached Files
OK David,
I installed the html folder (drhsEvolution) into the HTML folder in HS3.
The png's still dont appear.
I changed the setpoint on heat up 1 degree, and no change. attached is the log.
Edit:
I placed the drhsEvolution folder into the images folder, and now they appear.
But still no update.Attached Files
The png files should be HomeSeer\html\images\drhsEvolution. Are you running on Windows or Linux?
Your thermostat is behaving a little differently to mine. Is the MyEvolution app running OK, or did it break after enabling proxying via the plugin? Can you look at Wi-Fi/Advanced/Wi-Fi diagnostics/server packet status and compare the last successful times against the entries in the log?
In your logs I'm seeing multiple POST /systems/2913W000961, which is your thermostat sending its settings (setpoints and schedules) to the web service. I'd only expect to see these sent when something changes.
I'm not seeing any POST /systems/2913W000961/status messages. My thermostat sends these whenever the room temperature, outside temperature, humidity, etc., changes.
Is your thermostat prompting you for any firmware upgrades?
-David
Originally posted by drule View PostThe png files should be HomeSeer\html\images\drhsEvolution. Are you running on Windows or Linux?
-David
The .png's are all OK now.
The connection to the Bryant server is not connected, I think it broke when enabling proxying. I can still connect to the Bryant server with my PC, but the Thermostat has not connected sense 1:30PM, and the status says not connected. I am using Windows 7. The thermostat says the firmware is upto date. (No message about an update)
-David
Originally posted by drule View PostCan you disable the proxy, just to prove that is what broke it?
-David
What next?
Edit:
I disabled the plugin, and then enabled the proxy setting in the thermostat, and the connection dropped right away to the Bryant server, I then disabled the proxy setting, and the connection re-established.
Could the proxy port be the problem? I have it set to 08081.Last edited by KSO; February 21, 2015, 07:04 PM.
Originally posted by KSO View PostI disabled the proxy, and now it is connected to the server.
What next?
Edit:
-David
Originally posted by KSO View PostSounds Good. Thanks
-David
Originally posted by drule View PostWhile I tinker with the code, can you go to Plugins/Manage and enable developer mode? This will cause all your plugins to open up command windows. The thermostat plugin writes a lot of status info to its window, including any errors in may encounter.
-David
I have been trying several attempts. Tried changing the proxy port number, no luck. made sure the HS3 server and the router has 8081 forwarded, no luck. the connection to bryant server disconnects as soon as I enable proxy server on the thermostat. I looked at the log with developer checked, and it keeps stating processing connection to the thermostat IP address, then GET /Alive?sn=2913W000961. Then a little over 2 min later, ProcessingClientStream: An Existing connectionwas forcibly closed by the remote host - GET /Alive?sn=2913W000961. And this continues about every 2 minutes.
I attached the recent startup log.Last edited by KSO; February 22, 2015, 03:10 PM.
David,
I was thinking that the server settings for connection to Bryant may need to be changed if we are using a proxy server.
My server (Thermostat server setting) setting has a port setting of 80 to api.eng.bryant.com. should this be changed to 8081?
Edit:
Well I tried changing the server port to bryant to 8081, and that still disconnected me. Changed it back and I am connected to bryant again. Something about the proxy server settings.Last edited by KSO; February 22, 2015, 09:33 AM.
Edit:
-David
