Z-Wave Lock Events Script - Discussion Thread
  • Looks like the {} enclosed text for Pushover/RNCC items in question has solved the problem, no more "Event Has No Message Body - Error" messages. Mike
    Computer: CUK Intel NUC7i7BNH
    Op System: Windows 10 Pro - Work Station
    HS Version: HS3 Pro Edition 3.0.0.435
    Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
    • Originally posted by Ltek View Post
      sparkman
      Testing may have found a bug or 2:
      1. Not sure if this is by design... when I set a Lock code line item to 'Not Set' it never sends Pushover; even if Pushover Checkbox is checked.
      2. (log attached) seems the script reports 'Manual Lock' even when it should be 'Manual Unlock'
      For number 1, I'm not sure what you mean by "Not Set", can you clarify?
      For number 2, the script reports what it get's from HS's lock devices. It sends whatever it gets from that without modifying it.
      HS 3.0.0.548: 1965 Devices 1146 Events
      Z-Wave 3.0.1.262: 122 Nodes on one Z-Net
      • Originally posted by drparker151 View Post
        Just wondering out loud here. When I create a new code I have to hit submit after each entry. I wonder if when you remove a check mark and action if you have to hit submit on the blank as well to clear it?
        Yes.
        • The checkbox that says 'Not Set"
          Sent from my SM-G950U using Tapatalk
          • Originally posted by MNB View Post
            Al, quick one I'm in the midst of cleaning up my HS3 loose ends and noticed that I'm getting the following error message, any idea what I'm missing?
            I've since went into my DoorLock setup for each doorlock and updated my specific "Action Message" from [%PERSON% has unlocked the %DOOR%] to [%PERSON% has unlocked the %DOOR%]{%PERSON% has unlocked the %DOOR%} in the hopes that the {} enclosed text will take care of the Pushover error, thanxs in advance Mike
            Side note: is there anyway of knowing/denoting what the latest version of you script is?
            The behavior you seeing is how it is supposed to work. The [] tags are for speech only and the {} tags are for Pushover/RCCNM/email only. If you don;t use any tags, it would be used for all of those (speech/Pushover/RCCNM/email). Let me know if the wording in the Column Explanations at the bottom of the page is not clear and I'll update it.
            Right now you need to open the files in a text editor to see the version number. Should be 6.95 in the script file (doorlock.vb) and 6.9 in the web page (doorlock.aspx). I'll see if I can display them somewhere else for the next version.
              Ok, I see what you mean. For Pushover messages, a priority has to be set, but I'll probably change that in a future version to default to Low, if it is not set.
              • I thought, in the past, 'not set' still fired off a notice... Seems like it no longer does?
                • Originally posted by sparkman View Post
                  Al your Column Explanation is great what's missing is something that if I select "Pushover/RCCNM" column then I need to have the text in red also; [%PERSON% has unlocked the %DOOR%]{%PERSON% has unlocked the %DOOR%} otherwise you will receive any error in ones logs. I'm not sure if I use %PERSON% has unlocked the %DOOR% and have both "Pushover/RCCNM" and "Announce" columns selected if that would work?
                  I do not see version 6.9 in the Webpage, me thinks that would be good within the Settings Tab.. Mike
                    Hi Mike, yes, anything not enclosed in tags will get used by both. So %PERSON% has unlocked the %DOOR% , will work without having to repeat it enclosed by both sets of tags. I'll include the listing of the version numbers in the next update.
                    Cheers
                    Al
                      Maybe it did, I don't specifically recall, but will make sure it does in the next version.
                      • Thanxs Al for the confirmation. Mike
                        • I've had this working and suddenly I'm getting this error: Processing ASP.NET page: Object reference not set to an instance of an object.. So I upgraded to the latest version, but didn't make a difference.Any thoughts on how I can fix it?
                          Edit: I fixed it with these Instructions, this applies for Windows: https://forums.homeseer.com/forum/ho...ervice-or-task
