Z-Wave Lock Events Script - Discussion Thread
    Originally posted by racerfern View Post
    That was with columns expanded. Not a concern since the important part is that I get a text to my phone and that works perfectly.
    Thanks again.
    You’re welcome!
    There are some style settings at the bottom of the configuration page that control how that table displays. You can try playing with those settings using standard CSS style commands.
      My mind has failed me. I'm trying to get to the set up screen that modifies the text for the various codes.Opening doorlock.aspx (that's what I thought) just displays the text in chrome, it doesn't actually run the setup. Help please.
        When you say “the text”, what do you mean? There should be a drop down in the top left that allows you to select the overall config and the setup for each lock.
          Happy Thanksgiving! When I open doorlock.aspx with Chrome or with IE I get the text of the file rather than the file executing. I'm doing something stupid but can't figure it out.
Name:	Screen Shot 11-28-19 at 10.48 AM.PNG
            Looks lime you are opening the file direct, rather than through the HS web interface.
              I am. but I'll be darned if I can remember how through the HS3 web interface. Sorry, I took a couple of stabs but no joy.
                I just figured it out, Something popped into my mind and sure enough... 192.168.x.xx/doorlock.aspx. Whew! Thanks for putting up with me and again, sorry for bothering you.
                  No worries, and happy thanksgiving!
                    After trying every fix I was able to find and being unable to get aspx to work, I went ahead and ran the script to generate the .ini file. I am getting reporting and logging, but it is not correct for my device and doesn't have user names (I am using a Yale Assure lock). I am assuming those things are inserted into the .ini through the subsequent screens of the aspx. If that is the case, I am hoping someone can share a sample ini file so that I can get the formatting to input my specific lock descriptions and user names.
                      I'd like to download your doorlock script as a starting point for me to learn how to acces the homeseer.hsd db for reading device data.
                      But I cannot find (overlook) the link for downloading the script.
                        https://forums.homeseer.com/forum/de...=1#post1156347
                        Scripts =
                        Various
                          Thanks!
