I am currently trying to set this skill up, and all I get is a response from Alexa 'You are not authorized to use this skill'. I'm logged in using the same credentials with the Echo as I used to create the skill, any idea what I'm missing?
Thrag's Echo Plugin Discussion Thread
I have the bridge up and running and can control all my lights with Alexa. I did not install the skill because I didn't really need it. Coming from Vera, I was able to control my harmony scenes and devices, but I do not see a way to do it on this bridge. Is there a way to do this?
Andy
I'm trying to get this working and have failed at the first hurdle, setting up the HA Bridge.
I run HS on Server 2012R2.
I installed the JDK 1.8 to run.
I run the java file and towards the end I get errors telling me the Upnp Response Port is in use, starting loop to find open port for 20 tries......then it gets to 50020 with the message: Address already in use: Cannot bind.
I know little about java so any help would be appreciated.
P:\Program Files\Java\HA Bridge>java -jar ha-bridge-3.1.0.jar
2016-10-07 17:50:00,330 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v3.1.0) starting....
2016-10-07 17:50:00,345 [main] INFO com.bwssystems.HABridge.BridgeSettings - reading from system properties
2016-10-07 17:50:00,345 [main] INFO com.bwssystems.HABridge.BridgeSettings - Getting an IP address for this host....
2016-10-07 17:50:00,517 [main] INFO com.bwssystems.HABridge.BridgeSettings - Adding 192.168.1.12 from interface eth7 as our default upnp config address.
2016-10-07 17:50:00,517 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v3.1.0) initializing....
2016-10-07 17:50:00,533 [main] INFO com.bwssystems.HABridge.SystemControl - System control service started....
2016-10-07 17:50:00.689:INFO::Thread-0: Logging initialized @863ms
2016-10-07 17:50:00,720 [main] WARN com.bwssystems.HABridge.dao.DeviceRepository - Error reading the file: data\device.db - Does not exist or is not readable.
continuing...
2016-10-07 17:50:00,720 [main] INFO com.bwssystems.HABridge.devicemanagmeent.DeviceResource - HABridge device management service started....
2016-10-07 17:50:00,783 [Thread-0] INFO spark.webserver.JettySparkServer - == Spark has ignited ...
2016-10-07 17:50:00,783 [Thread-0] INFO spark.webserver.JettySparkServer - >> Listening on 0.0.0.0:8080
2016-10-07 17:50:00.799:INFOejs.Server:Thread-0: jetty-9.3.z-SNAPSHOT
2016-10-07 17:50:01.127:INFOejs.ServerConnector:Thread-0: Started ServerConnector@525daa03{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
2016-10-07 17:50:01.127:INFOejs.Server:Thread-0: Started @1311ms
2016-10-07 17:50:01,205 [main] INFO com.bwssystems.HABridge.hue.HueMulator - Hue emulator service started....
2016-10-07 17:50:01,205 [main] INFO com.bwssystems.HABridge.upnp.UpnpSettingsResource - Hue description service started....
2016-10-07 17:50:01,221 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener -
UPNP Discovery Listener starting....
2016-10-07 17:50:01,221 [main] WARN com.bwssystems.HABridge.upnp.UpnpListener -
Upnp Response Port is in use, starting loop to find open port for 20 tries - configured port is: 50000
2016-10-07 17:50:01,221 [main] ERROR com.bwssystems.HABridge.upnp.UpnpListener -
Upnp Response Port issue, could not find open port - last port tried: 50020 with message: Address already in use: Cannot bind
2016-10-07 17:50:01,221 [main] INFO spark.webserver.JettySparkServer - >>> Spark shutting down ...
2016-10-07 17:50:01.236:INFOejs.ServerConnector:main: Stopped ServerConnector@
2016-10-07 17:50:01,236 [main] INFO spark.webserver.JettySparkServer - done
2016-10-07 17:50:01,236 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v3.1.0) exiting....
A little progress but still not there.
After a little 'fettling' I managed to get a page that has;
HA Bridge Home MyEcho Help About
across the top.
After putting in my login details for Echo if I press the MyEcho tab I get to my echo account.
When I press /HS3EchoPlugin.aspx?BridgeConfig and wait a while I get;
Server Error in '/' Application.
Request timed out.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: Request timed out.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): Request timed out.]
I also notice when the java is run I am getting (highlighted in bold);
2016-10-08 15:36:25,639 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v3.1.0) starting....
2016-10-08 15:36:25,702 [main] INFO com.bwssystems.HABridge.BridgeSettings - reading from system properties
2016-10-08 15:36:25,702 [main] INFO com.bwssystems.HABridge.BridgeSettings - Getting an IP address for this host....
2016-10-08 15:36:25,874 [main] INFO com.bwssystems.HABridge.BridgeSettings - Adding 192.168.1.12 from interface eth7 as our default upnp config address.
2016-10-08 15:36:25,874 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v3.1.0) initializing....
2016-10-08 15:36:25,905 [main] INFO com.bwssystems.HABridge.SystemControl - System control service started....
2016-10-08 15:36:26,124 [main] WARN com.bwssystems.HABridge.dao.DeviceRepository - Error reading the file: data\device.db - Does not exist or is not readable.
continuing...
2016-10-08 15:36:26,124 [main] INFO com.bwssystems.HABridge.devicemanagmeent.DeviceResource - HABridge device management service started....
2016-10-08 15:36:26.139:INFO::Thread-0: Logging initialized @1528ms
2016-10-08 15:36:26,483 [Thread-0] INFO spark.webserver.JettySparkServer - == Spark has ignited ...
2016-10-08 15:36:26,499 [Thread-0] INFO spark.webserver.JettySparkServer - >> Listening on 0.0.0.0:8080
2016-10-08 15:36:26.499:INFOejs.Server:Thread-0: jetty-9.3.z-SNAPSHOT
2016-10-08 15:36:27.296:INFOejs.ServerConnector:Thread-0: Started ServerConnector@631ff8f8{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}
2016-10-08 15:36:27.296:INFOejs.Server:Thread-0: Started @2692ms
2016-10-08 15:36:27,499 [main] INFO com.bwssystems.HABridge.hue.HueMulator - Hue emulator service started....
2016-10-08 15:36:27,499 [main] INFO com.bwssystems.HABridge.upnp.UpnpSettingsRe
2016-10-08 15:36:27,514 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener -
2016-10-08 15:36:27,655 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener -
UPNP Discovery Listener running and ready....
My bad - typo in the echoconfig.ini file!!
Another hurdle completed, on to the Skill section!Last edited by IanIreland; October 8, 2016, 10:56 AM.
I am new to Homeseer and recently get the Echo bridge up and running (Thrags). I am not currently using the skill as I don't want to use the MyHS service. I was wondering if there is a way to have the echo run an HS3 event just with the bridge. Does anyone know if this is possible?
Andy
Andy
create a custom device this use this in the ON Button
http://HOMESEERIP:PORT/JSON?request=runevent&id=6220
change homeseer IP and Port , also change the event ID
You can find more commands here
http://www.homeseer.com/support/home..._with_json.htm
Thanks! Now I just need to read up on how to implement the JSON commands into the device.
Andy
Originally posted by rmohsen View PostSorry , i'm using HA Bridge and not Echo Plugin , i found it easier to use
Hmm, now I am confused. I am also using the HA-Bridge. No plugin or skill. Can you explain to me how to create the custom device and make it run the JSON?
Ah, I think I may now know what you are talking about when you say create a "custom" device. You mean to do this in the HA-Bridge interface right? If so, that is where I was getting confused. I was creating a virtual device in the HS3 interface.
Originally posted by ando1 View PostHmm, now I am confused. I am also using the HA-Bridge. No plugin or skill. Can you explain to me how to create the custom device and make it run the JSON?
Manual add your device , name it and then put the URLs in the ON and Off buttons .
once done scan your devices again from Echo
