JWP (Jim) (to question posted in the Script Library Forum?)
My guess is that your garage door script is named "sense_garage_door.txt" and that it got overwritten during a Homeseer update.
Whenever you modify a standard script to customize it to your house and unit codes for instance, it's best to rename it for just that reason (like "sense_garage_door1.txt"). I'll bet you'll find that the codes in your script are not set to the device codes in your setup. The old install package tended to revert scripts to the original downloaded version too, and perhaps that's what happened in your situation.
Also check to insure that this an X10 triggered event set to the house code and unit code of your tranceiver and the command is set to "extended code"
