' RadioRa Light Control Library for HomeSeer
' for use with Lutron's RadioRa system
' By Donald W. Smith Jr.
' DonaldSmith@SmartCondo.net
' http://www.smartcondo.net
' Summary:
' This script implements a control library for Lutrons RadioRa light control system.
' This script uses the RA-RS232 serial interface to communicate with the RadioRa system.
' This script requires the use of that device. This script is free to use by anyone with
' HomeSeer 1.5.42 or higher and the RadioRa serial interface.
' This script will povide feedback to HomeSeer for all RadioRa system activity.
' Configured HomeSeers X10 devices will be updated based on the current status of each device.
' Each RadioRa device, scene, LED, & master button can be controlled by this script.
' Revision History:
' 04/10/2002 v0.01 - Orginal crack at script (alpha)
' 06/08/2002 v0.02 - First test run with the the Lutron hardware (beta)
' 06/12/2002 v0.03 - Various tweaks (beta)
' 06/12/2002 v0.04 - Feature complete (test)
' 06/13/2002 v0.05 - Created device installation script/use INI settings
' 08/25/2002 v0.07 - Fix to master control feedback logic
' Setup:
' 1) Copy the script 'RadioRa.txt' into the HomeSeer scripts directory
' Copy the script 'RadioRaInstall.txt' into the HomeSeer scripts directory
' Copy the script 'RadioRaEvent.txt' into the HomeSeer scripts directory
' Copy the config 'RadioRa.ini' file the HomeSeer config directory
' 2) Configure your Radio device/zone names and locations in the [Zone Locations] & [Zone Names] sections
' Configure your RadioRa scene/button names in the [Button Names] sections
' Configure the [Configuration] section of the RadioRa.ini file
' 3) Add hs.Run "RadioRa.txt", "" to the startup.txt script
' 4) Run the "RadioRaInstall.txt" script to install the RadioRa device mappings
' 5) Call hs.RunEx "RadioRa.txt","SendCommand", [CommandString]
' from your event or script passing the appropriate command string
' (see RadioRa command reference)
' Todo:
' A) Create install script -done
' C) Use INI file -done
' B) Create an event trigger to trap an X10 event an map to RadioRa -done
' Examples:
' hs.RunEx "RadioRa.txt", "SendCommand", [CommandString]
' See reference RadioRa programming reference for [CommandString]
' Protocol Reference
Source
RadioRa.zip
Donald W. Smith Jr.
[This message was edited by Donald Smith on Thursday, 13 June 2002 at 08:11 PM.]
[This message was edited by Donald Smith on Tuesday, 27 August 2002 at 03:46 PM.]
' Summary:
' Revision History:
' Setup:
' Todo:
' Examples:
Source
RadioRa.zip
Donald W. Smith Jr.
