I have a number of scripts in the script library that place user-configuration definitions in a file homeseer.ini located in the homeseer root directory. Now that homeseer supports .ini I will be moving the definitions into the homeeer\config directory.
I am polling to see if I should continue to use a single homeseer.ini file, or should I use roughly one .ini file per library post such as Movies.ini, AudreyUtilities.ini, Guest.ini etc.
