Can I put the coding for a menu in the style sheet so it appears on all pages? Or is there somewhere else it shouuld go? It isn't a horizontal bar, its a slide out sidebar menu.
Dynamic Menu
MeSteveTags: None
MeSteve - I presume that you want to install a custom JavaScript menu on your site? If so and without seeing the menu, this needs to be called by each page every time it's loaded, so you would have to include the .js file within each of your html/asp pages and not within the style sheet. You do not have all the menu code in your pages but just a reference to your menu's JavaScript file.
for example
HTML Code:<script type="text/javascript" language="JavaScript1.2" src="menu/txpmenu1.js"></script>
The above is the code I use to call my menu, so I do not have to have a large peice of code within my html.
I'm just guessing as to this as there is not a lot of information within your post, I would however not know how to add this to the pages that HS creates on the fly, but would guess at some sort of framed page to get around this.
Hope this help in some way.
LanceLast edited by lancenorton; November 22, 2004, 06:15 PM.Lance
MeSteve
OK, so I use a meta.html or head.html and just put the reference in that, thanks all
Droop:
And there was just a post on removing the bar, you have to go into the .ini I belive and look for .logobar or #logobar and make it display:none. I know its not a lot of help, but it should get you looking in the right place until someone more knowledgable jumps in.
MeSteve
