I've got a third-party ActiveX object that I want to use from within an ASP page running under the HS2 web server. Is this possible, and if so, how do I set it up? I have the object registered on the machine and it is being referenced ok from VBScript (no ASP page errors), but it doesn't seem to be working (supposed to write an image file). I've checked permissions and I see no errors anywhere...
HS2 web server and ActiveX objects?
| - Gordon
"I'm a Man, but I can change, if I have to, I guess." - Man's Prayer, Possum Lodge, The Red Green Show
HiddenGemStudio.com - MaineMusicians.org - CunninghamCreativeMaine.websiteTags: None
Oh, I'm stupid tonight... I had a typo in the path to write the file. It works fine!|
| - Gordon
Check that again...
I'm trying to use an ActiveX object (DynImage.dll) that creates graphic images (PNG files) and writes them to disk. It works fine under the HS2 web server when using it in an ASP page.
However, it does not work (as in it does not write the file to disk) in an ASPX page.
Is there a way to make this work in an ASPX page? Or if this is the problem, is there a way to force this object to use VB code instead of .NET in an ASPX page?|
| - Gordon
Gordon,
Is it possible to post the bit of code in question as it is very difficult to see what you are doing.
Also, is there any reason you are wanting to use ASPX over ASP. I have been in communication with Rich and he has confirmed now that ASPX will be slower than ASP.
Here is a snippet from his email:
The problem is, communications between applications is slower with .NET (due to remoting and application domains), than it is with COM. I don't know why Microsoft would create a new technology and make it slower, but they did.
Hi, Jon00, sure.
What I'm doing is trying to retrofit UltraView2 with the ability to take the DeviceString of a device and create a .PNG image of it for use in UltraView2 on the fly. UltraView2 is using an ASPX file to do the work today - I just wanted to try to have some inline code to use the DynImage ActiveX object.
This is UltraJones' code in a file called ultraveiw2_common.txt, which is included in the basic ultraview2.aspx page with this line (less the opening sign):
Code:script language="VBScript" src="/ultraview2/ultraview2_common.txt"></script><SCRIPT language=VBScript src="/ultraview2/ultraview2_common.txt"></SCRIPT>
Here's the entire function code - the Case "Temps" is my section. The DynImage ActiveX object works with an ASP page, not in an ASPX page (spaces after the & to show the code in places):
Code:Function ProcessDevice(ByVal strDevType, ByVal strDevStr, ByVal iDevStatus, ByVal iDevDim) On Error Resume Next Dim arrStatus(1) Dim oDynImage Dim Dimage Const DEVSTR = 0 Const ICON = 1 ' ' Stip out html for tooltip display and set default icon value ' arrStatus(DEVSTR) = Strip(strDevStr, "<[^>]*>", "") arrStatus(ICON) = "unknown.gif" Select Case strDevType Case "RCS TX15B Thermostat", "RCS TX15B", "Temperature Probe" ' ' Special handling for devices that contain the status in the device string ' If arrStatus(DEVSTR) = "" Then ' ' Use unknown.gif ' arrStatus(DEVSTR) = "Unknown" arrStatus(ICON) = "unknown.gif" Else ' ' Attempt to convert device string to icon ' arrStatus(ICON) = BuildIcon(arrStatus(DEVSTR)) End If Case "Temps" if arrStatus(DEVSTR) = "" then arrStatus(DEVSTR) = "Unknown" arrStatus(ICON) = "unknown.gif" else 'Convert degree character to HTML degree arrStatus(DEVSTR) = replace(arrStatus(DEVSTR), "°", "& #176;") select case arrStatus(DEVSTR) case "." arrStatus(ICON) = mid(arrStatus(DEVSTR),1,(Instr(arrStatus(DEVSTR),".")-1) ) case "& #176;" arrStatus(ICON) = mid(arrStatus(DEVSTR),1,(Instr(arrStatus(DEVSTR),"°")-1) ) case else Set oDynImage = CreateObject("DynImage.DynImage") oDynImage.Open 50, 20 oDynImage.Color = &h000000 oDynImage.Rectangle 0, 0, 50,20 oDynImage.FontFace = "Tahoma Bold" oDynImage.FontWeight = 300 oDynImage.FontSize = 12 oDynImage.Color = &h000000 oDynImage.TextOut 7,03, arrStatus(DEVSTR) & "°" oDynImage.FontFace = "Arial" oDynImage.FontWeight = 500 oDynImage.FontSize = 14 Dimage = "C:\Program Files\HomeSeer 2\html\Images\HomeSeer\temp\test.png" oDynImage.SaveImage(Dimage) oDynImage.Close set oDynImage = nothing arrStatus(ICON) = "temp/" & arrStatus(DEVSTR) & ".png" end select 'arrStatus(ICON) = BuildIcon(arrStatus(ICON)) end if Case Else ' ' Attempt to make images identical to how HomeSeer displays them ' Select Case CInt(iDevStatus) Case 2 ' ' Device status is ON ' If arrStatus(DEVSTR) = "" Then arrStatus(DEVSTR) = "On" arrStatus(ICON) = "on.gif" Else arrStatus(ICON) = BuildIcon(arrStatus(DEVSTR)) End If Case 3 ' ' Device status is OFF ' If arrStatus(DEVSTR) = "" Then arrStatus(DEVSTR) = "Off" arrStatus(ICON) = "off.gif" Else arrStatus(ICON) = BuildIcon(arrStatus(DEVSTR)) End If Case 4 ' ' Deviced status is Dimmed ' If DarrStatus(DEVSTR) = "" Then arrStatus(DEVSTR) = "Dimmed to " & FormatPercent(iDevDim / 100, 0) arrStatus(ICON) = "dim.gif" Else arrStatus(ICON) = BuildIcon(arrStatus(DEVSTR)) End If Case Else ' ' Device status is Unknown ' If arrStatus(DEVSTR) = "" Then arrStatus(DEVSTR) = "Unknown" arrStatus(ICON) = "unknown.gif" Else arrStatus(ICON) = BuildIcon(arrStatus(DEVSTR)) End If End Select End Select ProcessDevice = arrStatus ' ' Test for and process error condition ' If Err.Number <> 0 Then Call ProcessError(Err, "ProcessDevice()") Err.Clear() End If End Function
If you need more, grab UltraStatus2 plugin and it loads the UltraView2 as well.|
| - Gordon
No thoughts about what the issue might be? <bump>|
| - Gordon
Hi Jon,
Thanks for the look-see. I don't know how to make the changes to the settings you spoke of, I'm just getting into HS2 and I've got to learn all the ins and outs of it.
I'll look around the board to find the places to make those changes you mentioned, then try some tests to see what errors I get.
If I can't use 'set', what do I use to pass the parameters to the object? That was the only way to do it in the ASP pages - a simple assignment would not work. I'm not that familiar with ASPX requirements.|
| - Gordon
PS Jon or others, I can't find the places to make the changes Jon suggested above (no web.config file, etc.).
Also, where can I find more about ASPX scripting? I don't see anything about it on MS' site... or at least their search engine isn't bringing anything noteworthy up.|
| - Gordon
Gordon,
After reading your first post, I see that the script you are trying to alter is called from the ASPX page and as it has the extension .txt, it will run in standard VB-script.
Have you tried extracting the image code and running it as a standalone script in HS2 to narrow down the problem? This should work using VB-script with no issues.
As for your other question about ASPX, it is really about scripting in VB.NET rather than VB-Script. If you can write a script in VB.NET, then you should be able to write a ASPX page.
There is no simple solution to conversion from VB-script to VB.NET as it depends on the complexity of the script. In very simple scripts, it may be just a matter of placing brackets around every command i.e.
hs.speak "Hello" becomes hs.speak ("Hello")
hs.waitsecs 2 becomes hs.waitsecs (2) etc
That said, several things have changed such as regular expressions, file manipulation, time etc.
There is no need to go down this route with your problem as VB-script still works very well in HS2.
It's got to be simpler than this!
I'm sorry, Jon, you've lost me. The ONLY thing I know about .NET is I don't like what it's doing to HS. I don't know anything about ASPX or VB.NET - I'm not a developer/programmer. I can write scripts all day long, VBscript, even WMI scripts.
First, the .txt file is INCLUDEd, not called, in the main ASPX script, so it is being acted upon as ASPX code, I believe.
"Image code"???? Oh, you mean the code supporting the ActiveX object I'm trying to use? The object runs properly under HS2 in an ASP page, but the UltraView code is ASPX.
Switching gears: How do I go about calling a VBScript script from the ASPX page? There are no examples in HS2 documentation or scripts/pages... and while I have the VBScript docs, there are none for VB.NET ("ASPX scripting") that I can find.
What do I download from the MS site to learn about this stuff? Where are the docs? Are there any MS white papers on how to convert from VBScript to VB.NET code? I've been all over the MS site and MSDN and can't find a darn thing...
Now, can you also answer how to set up the debugging in HS2.0 so I can see the results and debug codes and such?|
| - Gordon
Gordon,
I'm not a programmer either, I just trying to help you from the experiences I've learnt in the last few weeks as no one else responded to your post. The trouble here is that VB.NET is very new to Homeseer scriptwriters and very little published on what to do. If you are experienced in VBScript, it will not take you long to get an understanding of VB.NET with a little research on the internet.
My choice of words was wrong, however I assumed that when a file is 'included', Homeseer acts on the file extension. As I have no experience with this, I may be wrong and it may well act as an ASPX as you suggest.
To enable ASPX debugging, you need to do the following:
Copy the following text.
PHP Code:<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Next open up the main ASPX in question.
Add the following to the very first line of the page:
PHP Code:<%@ Page Language="VB" Debug="true" %>
Finally modify the image code to be .NET compliant:
PHP Code:oDynImage = CreateObject("DynImage.DynImage")
oDynImage.Close
oDynImage = nothing
PHP Code:Dim oDynImage As Object
Dim Dimage As String
Thanks, Jon, it didn't help. I have done some testing, but I can't get any errors to display and even Ultrajones' code doesn't show any errors (he traps many of them), even after adding the file and codes you mentioned and restarting HS2. I suspect that because this particular layer is a DHTML overlay, the errors (if any) are in a hidden window.
I did find one thing, though: just having the line "Dim oDynImage as Object" in the Function definition caused it to fail. No other changes were necessary, even when the code wasn't never run because nothing matched the Case statement parameters, and I still didn't get any errors.
Go figure. Apparently there is a lot more going on here than either of us knows, and it is related to Objects. Again, this is another reason why I don't care for the latest MS software. A script is no longer a script... and .NAT puts on many more idiosynchrasies. Whatever happened to good old BASIC? hehehe
I'm giving up for now. I need to learn this stuff on a simpler basis first. Thanks for all your help!|
| - Gordon
