I have the instructions
(Creating and Installing Certificate
This has worked with both Windows XP and Windows 2000 Pro:
Automated Installation by Mathewb and Rick Tinker
The attached certfiles.zip is everything needed to create and install a certificate to use SSL with Homeseer.
From the command line run the file runme.bat followed by a fully qualified machine or the local machine name.
Example:
Runme MyHSMachine.no-ip.com
or
Runme MyHSMachine
Manual Installation
The above install should be enough to get most people going. Below is the manual steps if you want to understand what it is doing.
1. Download: http://download.microsoft.com/downlo...s/makecert.exe
2. From the command line generate the signing authority:
makecert -pe -n "CN=Homeseer Root Authority" -ss my -sr LocalMachine -a sha1 -sky signature -r "Homeseer Root Authority.cer"
3. Also from the command line generate your key:
makecert -pe -n "CN=DOMAINNAME" -ss my -sr LocalMachine -a sha1 -sky exchange -eku 1.3.6.1.5.5.7.3.1 -in "Homeseer Root Authority" -is MY -ir LocalMachine -sp "Microsoft RSA SChannel Cryptographic Provider" -sy 12 homeseer.cer
Note: Replace DOMAINNAME with the fqdn or internal machine name. This could be either a foo.dyndns.org name, registered domain name, or internal computer name
4. There should now be a homeseer.cer and "Homeseer Root Authority.cer" files created, double click on both of them and install them when prompted. It's normal for the warnings, so click ok thru them.
5. Go to Start, then Run, type MMC and hit enter
6. From the File menu choose Add-Remove Snap-In
7. Click Add, choose Certificates and then Computer Acccount, accept all the as the defaults and hit Ok
8. Select Certificates, Personal and then Certificates
9. Select the certificate that should be listed as DOMAINNAME from above, and right click on it and choose export
10. Click next
11. Click "Yes, export the private key" and click next
12. Uncheck all of them and click next
13. Enter a password
14. Select the export file name, ie server.pfx
15. Copy the server.pfx file to the root of your Homeseer directory
16. In the Homeseer Web Server setup specify the password from step 13.) ............
After running the .bat file, I do not see a method of converting , or renaming the files created to allow the https configuration usable with HS.
2
Has anyone found a working step by step? I have created the files but where they go and which renamsing is not clear?
3
I want to use a non standard port . How do I configure this?
Thanks in advance.
