APCUPSD no longer updated
  • zwolfpack
    Excellent!
  • CeeTee
    PI up and running!
    Originally posted by zwolfpack View Post
    I presume you have apcupsd installed? The plugin relies on that.
    BINGO! I can't thank you enough for suggesting the AP UI instead of PowerChute. It installed without a hitch and I got the PI up and running within a minute.
    I'll hoist one up to your health! ...many, many thanks.
  • zwolfpack
    Its been awhile, but my recollection is that the drivers for Powerchute and apcupsd are incompatible. That is, if you want to run Powerchute you set the driver for the UPS to one thing, and if you want to run apcupsd you set it to another. Device manager screenshot below shows driver on my system.
    I presume you have apcupsd installed? The plugin relies on that. Follow the instructions to get that working first. (I like the apcupsd UI better than Powerchute's, so I uninstalled Powerchute after I got apcupsd working).
  • CeeTee
    started a topic APCUPSD no longer updated
    Hey all,
    I've only just noticed a while back that my APCUPSD PI (rev 3.2.0.5) is not getting data from the UPS (APC XS1300) ...and it would appear it hasn't since last September.
    The problem might not be the PI: Windows (7-32) device manager sees the UPS and appears to have the correct driver, but neither the PowerChute (Personal 3.02) software nor the PI seem to see the UPS anymore.
    After several attempts at fixes I uninstalled everything including the "device". When I plug the UPS back in, Windows recognizes the UPS and reinstalls the correct driver, but when I try to reinstall PowerChute it can't because it can't see the UPS; neither does the PI. If I click on "Enable" on the device page the icon goes green for a 1/2 second and then goes back to "disconnected".
    I'm using 127.0.0.1 and port 3551. And here's the error from the log:
    An unexpected error occured in the connect function/subroutine: [System.Net.Sockets.SocketException (0x80004005): No such host is known at System.Net.Dns.GetAddrInfo(String name) at System.Net.Dns.InternalGetHostByName(String hostName, Boolean includeIPv6) at System.Net.Dns.GetHostEntry(String hostNameOrAddress) at HSPI_APCUPSD.hs_socket_io.Connect(String RemoteHostName, Int32 RemotePort, Boolean usesSizePrefixedMsg, Boolean useASyncIO)]
    The warning is: Communication error with UPS1 upon connect: Connection refused.
    Anyone else having, or had, this issue?
    Does PowerChute, or any particular service have to be installed for the PI to work?
    Any ideas? I suspect it might be windows issue subsequent to an update.
    urrent Date/Time: 3/18/2017 4:40:54 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.313
    Operating System: Microsoft Windows 7 Professional - Work Station
    System Uptime: 0 Days 0 Hours 39 Minutes 0 Seconds
    IP Address: 192.168.2.111
    Number of Devices: 408
    Number of Events: 138
    Available Threads: 400
    Enabled Plug-Ins
    3.2.0.5: APCUPSD
    2.0.57.0: BLDSC
    2.0.11.0: BLiTunes
    2.0.3.0: BLMarantz
    1.0.3.0: BLShutdown
    3.0.21.28949: Blue-Iris
    1.1.2.0: Device History
    3.0.1.10: HCS2
    3.0.0.75: HSTouch Server
    3.0.6.0: Insteon
    3.0.1.84: PHLocation
    3.0.0.63: weatherXML
    3.0.1.93: Z-Wave
