Are these UPS supported ?
  • Are these UPS supported ?
    Hello
    I just bought these 2 UPSs and i'm trying to figure out how to make them work with the plugin
    Each is working fine with it's own power management software but i'm trying to figure out how to connect them to the plugin ( if they are compatible )
    Having some problems figuring out how to configure APCUPSD and NUT on windows
    https://system-max.com/product/systemmax-smu-600slu/
    http://powerquality.eaton.com/ENV600H.aspx?cx=31
    Rami
    I am not familiar with these two UPSs. If they are supported by APCUPSD or NUT then the plugin can eb used as it communicates with the APCUPSD or NUT services on the computers rather than directly with the UPS. Therefore either APCUPSD or NUT need to be running/configured on the computer before looking at integration with HS3 with the plugin. Have you checked the http://www.apcupsd.org/ and https://networkupstools.org/ sites / supports? I would start with that to check if supported and/or how to configure the respective drivers to support the UPSs.
