Device Images
  • Device Images
    Many moons ago I found an option to change the images for this plugin. Now I want to go back to the original images installed when I installed the plugin. I cant find that option.
    Attached are current images.
    System Information
    Current Date/Time: 9/13/2018 9:28:43 AM Eastern Daylight Time
    HomeSeer Version: HS3 Standard Edition 3.0.0.470 (Windows)
    HomeSeer: Is Registered
    Operating System: Microsoft Windows Embedded Standard - Work Station
    OS Version: 6.1.7601 Service Pack: 1.0
    System Uptime: 4 Days 1 Hour 2 Minutes 15 Seconds
    User Name and Access Level: default (Admin)
    LAN IP Address: 192.168.1.215 (hometroller)
    Client IP Address: 192.168.1.225 (Vizio.fios-router.home)
    External IP Address: 71.104.37.56 (pool-71-104-37-56.nwrknj.fios.verizon.net)
    Network Adapter: Adapter -> Realtek RTL8188EE Wireless LAN 802.11n PCI-E NIC IP: 192.168.1.182/24 MAC: B0:C0:90:92:96:96
    Network Adapter: Adapter -> Intel(R) I211 Gigabit Network Connection #3 IP: 192.168.1.215/24 MAC: 80:EE:73:BE4:11
    Network Adapter: HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1
    Web Server Port: 80
    Number of Devices: 455
    Number of Events: 61
    Event Last Ran: Virtual : Dryer Status Off, Ran at 9/13/2018 9:28:42 AM
    Number of unique event scripts used: 0
    Connected Speaker Clients: HOMETROLLER (192.168.1.215)EFAULT, HOMETROLLER (192.168.1.155):ANDROID, HOMETROLLER (192.168.1.238):ANDROID
    Plug-Ins Enabled: LutronCaseta:,UltraCID3:,UltraLog3:,UltraSMTP3:,UltraMon3:,U ltraM1G3:,EasyTrigger:,Device History:,Z-Wave:,SDJ-Health:,APCUPSD:
    Processor Type and Speed: x64 Family 6 Model 61 Stepping 4 at 1.38 GHz
    Modules/Threads: 140 Modules, 107 Threads
    Available Threads: 200
    System Processes/Load: 92 Processes, 96% Load
    Free / Total Physical Memory: 407.66 MBytes / 1.89 GBytes (21% free)
    Free / Total Virtual Memory: 2.21 GBytes / 3.78 GBytes (58% free)
    HomeSeer Memory Used: 132 Mbytes
    Plug-In Memory Used: 11 EXE Plug-Ins using 326 Mbytes
    Stop the plugin, edit the plugin config file hspi_apsupsd.ini and remove the row starting with gIconSet and restart the plugin. It will run the script install the icons as current based on the icon set selected in HS3.
    The currently used icons by the plugin are in {HS installation root folder}\html\images\apcupsd\status. Most likely you overwrote icons in this directory. To ensure these are the icons referenced in your setup after you tweaked it a while back, right click on an icon in the device page (screenshot above) and check the image path. The above steps will refresh the content of that directory.
      Thanks for the reply.
      I followed the instructions and I always go back to the status Icons. I even went into the ini file and changed it to contemporary and no luck.. I uninstalled the entire plugin as per the uninstall instruction and after installing the plugin again I still see the status icon. I would like to go back to the contemporary icons.
        This where the images are located. images/apcupsd/status/battery_gear.png. By the this image is missing.
