APCUPSD devices are not visible in Event configs
  • APCUPSD devices are not visible in Event configs
    Hi Philippe,
    As part of my final push to complete my conversion from HS2, I was looking for a way to run an event based on a value changing in one of the APCUPSD devices (UPS1 Status in this case). However, the APCUPSD devices are not visible in the "If A Device's Value is..." triggers. Can you update the plugin to expose them there?
    Al
    Are you using the latest plugin version and did you create the devices with the latest version? This was an issue with an earlier version and thought I fixes it. I will double check as well.
      Hi Philippe,
      Latest version, but I believe the devices were created with the first released version. Should I stop the plugin, delete the devices, and then restart the plugin?
      Al
        Hi Philippe,
        Recreated the devices and all is good now.
        Al
          Wonderful!
